Removing/Installing Speedsensor
Old Mar 31, 2003 | 06:32 PM
IEATLINT's Avatar
Default Removing/Installing Speedsensor
How do i remove and/or install a speed sensor. i don't think it matters but i have an ls engine/tranny
Old Mar 31, 2003 | 11:10 PM
IEATLINT's Avatar
Default Re: Removing/Installing Speedsensor (IEATLINT)
Bump Bump
Old Mar 31, 2003 | 11:11 PM
im_poor's Avatar
unclip the plug, and you unbolt it from the tranny.
Old Mar 31, 2003 | 11:14 PM
JDMjdawg's Avatar
Its extremely easy... Just loosen the bolt, I think its a 10mm, disconnect the plug, then you just pull up on the speed sensor. When you go to put it back in, you just slip it in gently, you should just make the bolt wrist tight. You don't wanna break the plastic around the bolt on the speed sensor. Good luck
[Modified by JDMjdawg, 8:14 AM 4/1/2003]
IA95civicDX
May 15, 2009 10:29 PM
ThinkRevolution
Nov 19, 2006 02:39 PM
BAYgasDC2
Jul 7, 2005 11:22 AM
esca
Sep 25, 2004 09:20 AM
Edwardo911
30
Sep 10, 2004 01:43 PM
