manifold help!!!
Old Mar 31, 2003 | 04:16 PM
cyberx's Avatar
Default manifold help!!!
what manifold is better for me, the y8 Automatic or Y8 manual??????? i tryed searching but the archive search is dissabled at the moment so i cant answer my questiont through searching....... i have a d16a6 engine.... manual trans.... i heard something a while back that the automatic manifold is better because it comes with a sensor part that is located on the throttlebody on the manifold..... so that if i get a throttlebody i wont have to hook anything up to it....... is this true???? i need to find out before i purchase....... i have sellers for both manual tranny and auto, and i need to find out before i make a mistake on buyin the wrong one........ thanks
Old Mar 31, 2003 | 05:03 PM
zCivic's Avatar
Default Re: manifold help!!! (cyberx)
you need a 5sp intake manifold. The 5sp has the IACV located in the back of the Intake mani like A6's and Z6's while the A/T has it mounted on the T/B which will not work
Old Apr 1, 2003 | 01:28 PM
allmotorman's Avatar
Default Re: manifold help!!! (zCivic)
the auto manifold has the boss for the eacv,it just needs to be drilled and tapped.
Old Apr 1, 2003 | 03:31 PM
zCivic's Avatar
Default Re: manifold help!!! (allmotorman)
more work and money for the IACV just get the 5sp and be done with it
Old Apr 1, 2003 | 03:59 PM
Malgerus's Avatar
Can't you just change plugs for the IACV, since it is on the throttle body, and be done with it? Or is it too different?
Old Apr 1, 2003 | 04:01 PM
zCivic's Avatar
Default Re: manifold help!!! (Mr. S)
To my understanding its too different..... I know The throttle body uses 3 wires that kinda oval shaped plug while the M/T still uses 2 wires in a round plug
rhdekhatchie
Mar 1, 2008 11:22 PM
immajackuup
Feb 28, 2008 10:41 PM
dw.VTEC
Apr 8, 2005 03:59 PM
sloweredcivic
Jan 17, 2004 09:27 PM
crx(gator)
Mar 26, 2003 09:19 PM
