Need Helms Manual lookup!!asap
Old Mar 31, 2003 | 03:53 PM
4gen's Avatar
Default Need Helms Manual lookup!!asap
Wiring my H22A with Summit RPM activated switch and Autometer mini-shift lite. Need to know which wire in distributor is for RPM signal. Posted a topic earlier relating to this subject of wiring up the shift lite, but everyone got the impression that i had the same wiring as the fourth gen prelude, well i dont have the "RPM tach test wire" as i was refered to. So i need the helms manual lookup for this particular wire color and location inisde the dist., thx in adv.
Old Mar 31, 2003 | 04:31 PM
4gen's Avatar
Default Re: Need Helms Manual lookup!!asap (4gen)
^^^bump, bump^^^
Old Mar 31, 2003 | 04:37 PM
Jonathan_ED3's Avatar
If there's a blue colored wire in there, it's deff. that one
If not, I've got no clue.
Old Apr 1, 2003 | 12:12 PM
prelittlelude's Avatar
Default Re: Need Helms Manual lookup!!asap (hot_EG)
I just finished wiring up my tach and shift light last nite, there are a bunch of places to tap in, i have a 4th gen 94 vtec, and i just went under the dash and unplugged the cruise control module plug (its a big silver box under the drivers side dash) there is a blue wire that goes in there, that you RPM signal wire, and i didn't want to tap in there, so i got out my meter and tested some of the other blue wires that i tried to follow from the cruise unit, and i found on thats one of the first plugs that goes into the under dash fuse box, its def a BLUE wire. hope this helpped good luck.
high-rev
Sep 11, 2007 09:39 AM
sleepy_vtec
Mar 17, 2005 08:20 AM
SocalChris
Oct 7, 2004 10:32 PM
superthug
Jun 21, 2003 05:58 PM
4gen
Mar 30, 2003 08:51 PM
