shaking problem
Old Mar 31, 2003 | 03:24 PM
Rob!'s Avatar
Default shaking problem
i just finished my swap and when i took it for a spin it ran fine but when i go to turn at like any speed over 10 mph the front end of the car shakes like crazy. even when going around a bend it shakes...it almost feels like the wheels are gonna fall off. anybody know what this can be? lugs are tight. the drivers side axle is brand new. anyone ever have this problem before? do your best to help me out
Rob
Old Mar 31, 2003 | 03:42 PM
bryant's Avatar
Default Re: shaking problem (RaceFacer)
Any unsual noises or just shaking? Does it shake when driving straight.
Might just need your tires rebalanced.
Old Mar 31, 2003 | 03:55 PM
Rob!'s Avatar
Default Re: shaking problem (Bryant)
doesnt shake when going straight but soon as i turn shakes like crazy
Old Mar 31, 2003 | 03:56 PM
Rob!'s Avatar
its not a slight shake....for real itfeels like i have a flat tire or i have one lug on there and and its on by 4 threads
Old Mar 31, 2003 | 04:26 PM
TRE_'s Avatar
hey, i'm having a similar problem.. just put the zc back in my rex and at first it was ok, but now i hear this loud rattle... doesnt sound exactly like your prob but similar(sorry if i'm hijacking your thread). any help for either of us? i was thinking it may be the exhaust? it happens while i'm driving strait and turning.
[Modified by glowing_rotors, 5:27 PM 3/31/2003]
Old Mar 31, 2003 | 04:33 PM
RuffRhyno's Avatar
hhmm check the obvious first...I would suspect it has somethign to do with the axles...or maybe your suspension. You tightened down all of your bolts and put the cotter pins back in place? Double and triple check to make sure they are tight.
Hey where in NJ you located?
[Modified by RuffRhyno, 1:33 AM 4/1/2003]
Old Mar 31, 2003 | 05:02 PM
Donkey85's Avatar
Default Re: shaking problem (RuffRhyno)
warped rotor??? just throwing out an idea, a warped rotor will cause shaking when driving almost like an unbalanced tire
Old Apr 1, 2003 | 05:41 AM
Rob!'s Avatar
I am located in central jersey...brunswick/princeton area middlesex county
Old Apr 1, 2003 | 08:40 AM
DJ_SaNdOz's Avatar
what swap? was it a b series? if so, did you remove teh dust seal on teh axle?
teg969
Apr 25, 2007 03:41 PM
mvp97gsr
Feb 21, 2006 09:27 PM
Behan
Apr 23, 2004 08:04 AM
TSIntegra
Jun 5, 2003 11:25 AM
yeaaaa its slow
15
Dec 16, 2002 01:56 PM
