can stock ignition coil handle boost?
Old Mar 31, 2003 | 12:10 PM
SpeedMonkeyRacing's Avatar
Default can stock ignition coil handle boost?
i'm currently running stock coil w/ msd digital 6. do you think i think i should upgrade it aftermarket coil asap or those stock coil can handle power?
Jeff-
Old Mar 31, 2003 | 12:13 PM
b16ahybrid's Avatar
Default Re: can stock ignition coil handle boost? (Corporal-Jeff)
How much boost are you running? stock coil should be fine...works fine for me
boosted hybrid's Avatar
Completely stock ignitions have seen past 400whp. I have personally pushed a completely stock internal/stock ignition gsr block to 18~19psi on race gas. I had no problems with blowing the flame out. Depending on your horsepower goal (under 500whp) I'd just run the MSD 6A.
Old Mar 31, 2003 | 12:45 PM
Default Re: can stock ignition coil handle boost? (boosted hybrid)
well, right now...i'm just gonna make out the t3/t4 turbo that's currently on the car (<400whp). However, I prolly will go going back in the summer and pushing over 500whp. Guess i don't have to worry about it now when i upgrade my setup
thanks guys
Jeff-
Old Mar 31, 2003 | 01:04 PM
TurbothisLS's Avatar
it seems like the stock coil and ignition is good enough, but will the external coil with an ignition help a lot?
HYREV2NR
May 6, 2006 06:52 AM
turboman
Apr 14, 2006 02:37 PM
trusttuned
Apr 28, 2005 12:48 PM
dunkd
Aug 9, 2004 05:25 AM
SiRkid
Oct 31, 2001 01:16 PM
