Temperature gauge on si cluster.....
Old Mar 31, 2003 | 08:57 AM
CM-R's Avatar
Default Temperature gauge on si cluster.....
My engine temp gauge is shooting up to hot even though my engine is completely cold....Is there a senor on the engine some where i can look at to see if it is loose or is my Si gauge acting up? This is happening to my 96 EK hatch with a 99/00 SI gauge cluster.....
Old Mar 31, 2003 | 10:24 AM
4g4me's Avatar
Default Re: Temperature gauge on si cluster..... (CM-R)
right under the distributor.....play with the plug....probabally got a lil oil on your contacts....if it is oily, fix the leak...
edit: also....plug in your original cluster...just to see if it acts up as well...eliminate the cluster as being the problem...
[Modified by 4g4me, 1:26 PM 3/31/2003]
Old Mar 31, 2003 | 10:39 AM
Ehron's Avatar
Check the ECT switch right next to the lower radiator hose. When my temp guage didn't work that was the culprit. It wasn't erratic though; it just did not work at all.
HTH.
Old Mar 31, 2003 | 01:30 PM
CM-R's Avatar
Thanks guys i'll go check it out right now....
Old Mar 31, 2003 | 01:31 PM
CM-R's Avatar
This just happened when i got my car towed and had put in new axles after i broke the other ones.....
Old Mar 31, 2003 | 01:34 PM
CM-R's Avatar
What color are the plugs for both the plugs you guys are talking about? Oh yea i have a 96 GSR motor in my EK
[Modified by CM-R, 2:35 PM 3/31/2003]
Old Apr 2, 2003 | 12:56 PM
CM-R's Avatar
Can you anyone describe how the plugs look like....
FloresEM1
Aug 12, 2011 01:52 PM
o0ohaviko0o
Apr 1, 2008 07:04 AM
Pure Sol
Apr 24, 2005 08:01 PM
Rhetoric
Sep 14, 2001 06:55 PM
