knock sensor???
Old Mar 31, 2003 | 08:30 AM
joshwhe's Avatar
Default knock sensor???
well im swaping my b18a1 out for a b18b and was wondering what i do about the knock sensor considering the b18b i dont think has one ,... and ill be running a 91 non obd pr4 ecu
Old Mar 31, 2003 | 08:40 AM
Mr.Saturn's Avatar
Default Re: knock sensor??? (joshwhe)
Unless your going LS/VTEC you shouldn't need one
Old Mar 31, 2003 | 09:07 AM
zCivic's Avatar
Default Re: knock sensor??? (Mr.Saturn)
only DOHC V-tec engines have a knock sensors, Non-vtecs dont.
Old Mar 31, 2003 | 09:09 AM
joshwhe's Avatar
Default Re: knock sensor??? (zCivic)
so then my old one didnt have a knock sensor.... ok so then there will be no cel? thanks
Old Mar 31, 2003 | 09:19 AM
zCivic's Avatar
yep your ol B18A didn't have one and your new B18B doesn't either, wouldn't throw a CEL unless your using a DOHC-VTEC ecu
Old Mar 31, 2003 | 09:28 AM
joshwhe's Avatar
great.. thanks for the help.. so the b18b has all the same sensors as my b18a
Old Mar 31, 2003 | 09:47 AM
zCivic's Avatar
yep, different injectors though, there saturated while the 90-91s are peek hold. Just swap the injectors or remove the injector resistor box
Old Mar 31, 2003 | 10:35 AM
joshwhe's Avatar
while i have to use my head so im gonna stick with my injectors ,.... does theb18b have a thermoswith ??? and is that important im thinking it turns my fans on but am unsure
Old Mar 31, 2003 | 11:11 AM
Mr.Saturn's Avatar
yes the B18B does, its in a different place than the B18A, although I'm not sure exactly where, and I can't search archives to find out
Old Mar 31, 2003 | 01:44 PM
joshwhe's Avatar
humm.. ok thanks.. well i guess ill just have to look at it when i get the thing
Old Mar 31, 2003 | 03:21 PM
Mr.Saturn's Avatar
B18A has it in the back of the block, just to the left of the oil filter. I could be wrong but I think I remember reading the thermoswitch on B18B was in the head. Can anyone confirm?
SiAutoX
Mar 22, 2006 03:10 AM
mdixonjam
May 22, 2005 03:48 PM
Greasemonkey
Apr 10, 2004 07:31 PM
mskibbz-T
Nov 13, 2003 03:48 PM
X2BOARD
Mar 11, 2002 02:58 PM
