ecu is throwing code 9, No 1 Cylinder Position ?
Old Mar 31, 2003 | 08:21 AM
lowboost civ's Avatar
Default ecu is throwing code 9, No 1 Cylinder Position ?
what could this be
Old Mar 31, 2003 | 11:40 AM
jdmsol's Avatar
Default Re: ecu is throwing code 9, No 1 Cylinder Position ? (lowboost civ)
Time for a new distributor my friend. It's happened to me twice.
Old Mar 31, 2003 | 01:13 PM
built562's Avatar
try resetting the timing and then check, did you do any engine work latley where you may have changed the engine postion like cams/timing belt/crank pulley
any of these you may have accidentaly turned the engine moving it from tdc.
Aposiopesis
Jun 20, 2019 08:36 AM
2010coupe
Oct 31, 2012 05:53 AM
90civic-ZC
Nov 21, 2011 06:45 PM
eclipsedsundown
Jul 23, 2011 10:59 AM
tdc
Jul 21, 2002 07:54 PM
