will a b20 head fit onto a b18b block????
What would you hope to accomplish by putting the B20 head on the B18b block?? Serious question. Why not do a LS/VTEC?
It's not exactly the same. The bore on a B20 is bigger than a B18, 84mm vs. 81mm. So... the combustion chambers will be bored out slightly wider. Youc an put it on, though you'll get a hot-spot at the top of the cylinder where the combustion chamber doesn't match it right to the edge.
Are all of you guessing or what?
NO, the combustion chamber is not bigger, the two heads are the exact same casting, there is not one damn difference at all.
It will be exactly the same as an LS, the only variable is cams.
-Brian
-Brian
GoHardEH2
Jul 16, 2007 08:27 PM
