Do you re-use the factory dust cover with aftermarket springs and struts??
Old Mar 30, 2003 | 09:46 PM
crex23's Avatar
Default Do you re-use the factory dust cover with aftermarket springs and struts??
I have a 89 CRX DX with bouncy front suspension. I've tried several different things to stop this, and I'm thinking that when the strut is compressed, the dust cover is bottoming out on the strut seat. Is this possible? Anybody have this problem? BTW, I'm using the stock factory black dust cover. Thanks for the replys.
Old Mar 30, 2003 | 10:09 PM
the DR.'s Avatar
Default Re: Do you re-use the factory dust cover with aftermarket springs and struts?? (crex23)
alot of times those things do get stuck to the shock body of the new shock, which could possibly cause that, it happened to me a while back
Old Mar 30, 2003 | 10:14 PM
sporkcrx's Avatar
Default Re: Do you re-use the factory dust cover with aftermarket springs and struts?? (SlicedBread)
I don't even remember having dust covers on my shocks, haha
Old Mar 30, 2003 | 10:21 PM
crex23's Avatar
Default Re: Do you re-use the factory dust cover with aftermarket springs and struts?? (sporkcrx)
So will it be ok to run without the dust covers? I thought crap from the road like dust, grime, etc. could get in your strut and damage it. Or should I try trimming them? I've also heard of using the accordion-like dust boots. Where are these sold? Thanks alot for the help.
Old Mar 31, 2003 | 04:35 AM
keithv's Avatar
i would try to get some kind of cover if you daily drive the car, especially if its in the winter of a snow climate. salt can corrode the shock piston.
i don't like trimming the dust covers since they will leave a certain part exposed since you need to trim it when the suspension is at full compress.
i read a post a while back about using the steering rack covers on shocks. the steering rack uses accordian style rubber sleeves.
hth.
Old Mar 31, 2003 | 04:42 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: Do you re-use the factory dust cover with aftermarket springs and struts?? (breaka_1_9)
kyb actually makes a rubber accordian style dust cover...it mounts solid on top and bottom and just compresses and stretches. i cant think of how to describe it...
i think i actually saw them for sale on www.tires.com. i think....cause they sell suspension stuff too. or else look on the kyb site.
Old Mar 31, 2003 | 08:05 AM
civbeater90's Avatar
Default Re: Do you re-use the factory dust cover with aftermarket springs and struts?? (fastcrxsi90)
i cut mine down and it works just fine
Tong.Y
Jun 4, 2010 08:31 PM
corej87
May 19, 2008 11:13 PM
l2agnar0k
Feb 28, 2005 04:27 PM
DJ_CARY
19
Aug 9, 2004 12:26 PM
Slow&Furious
Nov 15, 2001 05:42 PM
