How to adjust TOE and CASTER ????
Old Mar 30, 2003 | 09:30 PM
eg6madness's Avatar
Default How to adjust TOE and CASTER ????
how do i adjust these on a 94 civic hatchback ??
Old Mar 30, 2003 | 11:15 PM
M-EJ1's Avatar
Default Re: How to adjust TOE and CASTER ???? (eg6madness)
Caster is not adjustable unless you want to swap the control arms left to right. If you're talking about camber, you need a camber kit to be able to adjust the camber. Toe is adjusted at the tie-rods.
However, unless you have the correct equipment (IE, alignment machine), this is stuff you should really leave to the pros. You can get it close with a tape measure in some cases, but you really need to have it adjusted correctly or else your car will handle unpredictably (which can be dangerous) and your tires will wear abnormally (which can also be dangerous).
[Modified by M-EJ1, 12:16 AM 3/31/2003]
Noah Santana
11
Jan 18, 2017 06:09 AM
mouseitr
Suspension & Brakes
12
Apr 1, 2012 06:34 PM
blkcivic310
11
Mar 11, 2010 03:57 PM
JdmB16Eg6
Suspension & Brakes
Mar 28, 2006 10:29 AM
SIRIUS
May 27, 2005 05:48 AM
