ZC wont start.. leaking injectors
Damn this is frustrating, I worked day after day 12+hrs and I try to start it, and it just sits there and turns over trying to start.. I think its either getting no fuel or no spark. Injectors #2 and #3 are leaking fuel all over the place.. how do I fix this?
Do I have my plug wires right?
What am I supposed to do with this.. would it stop the ZC from starting?
And here are the two leaking injectors..
What are some common things that people seem to skip over when doing their swap that keep the engine from starting?
Im pretty sure I didnt **** it up.. I took my time with the wiring, I changed the firing order a lil just now and now it starts!! but its idling real weird and low and backfiring, Im getting a code 7 now. Anyone know what it is?
code 7 is throttle position angle (aka TPS) get a voltmeter and adjust your TPS
4.5v for WOT
.5v for closed
also having injectors leaking isnt a good thing either...
4.5v for WOT
.5v for closed
Are your injectors still leaking ? If so check the little o ring on them, you could of broke one while putting them in or they could of just been old and worn away.
Last time I checked they werent leaking anymore.. I just pushed em in more and they seemed to be ok from then on, didnt see any more fuel on the ground and didnt smell fuel anymore.
zchatch24
13
Feb 26, 2012 08:47 AM
