Question about Expo Rules (safety)
Old Mar 30, 2003 | 05:57 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Question about Expo Rules (safety)
"Roll Bars/Cages: Roll bars are advised for the event, but not required. (In the event a non-ITR participates in the event, this rule will be reviewed.) Any roll bar must be able to withstand the compression forces involved in the supporting the full weight of the car in extremely adverse circumstances. All cars with roll bars and roll cages must meet the NASA CCR requirements, must be mounted correctly according to the NASA CCR, and all roll bars and roll cages must be adequately padded with the correct material."
* Now, does this mean you have to have padding? I know it says it, but I currently have no padding on a roll bar. I can understand adequate padding on a roll cage, but roll bars as well?
"Seatbelts and Harnesses: Seatbelts must be in new or perfect condition. No damage may be present, and they must be factory configuration. Any harness system must be of an approved design, and can be used only in conjunction with approved rollover protection. Driver and passenger should have the identical restraint system."
* Identical meaning same make, model, color, etc... or same point? 4 pt/4pt, 5pt/5pt.
"Seats: All seats must be securely fastened to the structure of the car. Driver and passenger seats should be of the same configuration, preferably exactly the same. Non-stock seats should be FIA certified."
* What if your driver seat is different than that of the passenger? Ex: Recaro driver seat vs. stock passenger seat?
Thanks for the update
Old Mar 30, 2003 | 06:06 PM
lanceh's Avatar
25 Year Member
Default Re: Question about Expo Rules (RealTypeR)
gut questions because i'm in the same situation for all three issues you listed
-no padding on the rollbar
-driver 5pt and passenger 6pt
-driver aftermarket seat passenger stock seat
ZygSpeed's Avatar
Since I edited the rules for the program ... hehe
1) yes, you need padding in areas where a driver or passenger might contact the tubing.
2) since the rules require a crotch strap, the belts must be at least 5-pt, the same seats do not need to be provided to the passenger/instructor (though it is strongly advised for style points).
3) identical restraint systems ... both have race belts! .... or just OEM belts!
Ed
[Modified by zygspeed, 10:07 PM 3/30/2003]
Old Mar 30, 2003 | 06:11 PM
Default Re: Question about Expo Rules (zygspeed)
Thanks Ed. Shouldn't you be working on your motor?
My instructor will be wearing baby blue harnesses while I'm pimping the black ones.
Can't wait.
Marc ----> who thinks he knows who his instructor is
Old Mar 30, 2003 | 06:18 PM
ZygSpeed's Avatar
I think the motor's in the car, the custom tranny needed another gear.
Old Mar 30, 2003 | 06:21 PM
look out...better hurry and get that bad boy on the street. Only 12 more days to work on it. Maybe we'll see you at CMP
lanceh's Avatar
25 Year Member
you going with one of those 7-speed, semi-automatic clutchless systems.?.?
Old Mar 30, 2003 | 06:23 PM
Default Re: Question about Expo Rules (lanceh)
push button shifting
Old Mar 30, 2003 | 06:24 PM
ZygSpeed's Avatar
none, direct drive with the turbine!
... another gear
lanceh's Avatar
25 Year Member
a friend from college had one of those old beasts.
Old Mar 30, 2003 | 06:30 PM
Chris N's Avatar
People know who their instructor is already???
Old Mar 30, 2003 | 06:37 PM
Mugen Mike's Avatar
Default Re: Question about Expo Rules (Chris N)
No
Old Mar 30, 2003 | 07:24 PM
lanceh's Avatar
25 Year Member
Default Re: Question about Expo Rules (George Knighton)
ok now we have two differing statements from the powers that be on this subject. i would very much like trey to comment on these questions.
i have never ever heard of any driving school that requires the same brand and design of harness for both passenger and driver. type (oem vs. harness) is one thing but please explain the reasoning for the same brand.
the same goes for the seat. i have never seen a driving school that requires the passenger to have a bucket if the driver does.
my opinion is the belt and seat requirements are completely unrealistic.
Old Mar 30, 2003 | 07:26 PM
R134's Avatar
Would a reclinable Recaro SRD be ok? What about something like a Mugen S1 seat (not FIA)? Having everything exactly the same does sound unrealistic.
[Modified by R134, 11:27 PM 3/30/2003]
Old Mar 30, 2003 | 07:32 PM
Reid's Avatar
Global Moderator
The rules were clearly laid out for all of us, a while back, and it was made clear that seating and harnesses for driver and passenger must be identical.
Being that ALL of our cars came with identical passenger and driver seatbelts and seats, there is no reason why anyone would be unable to follow the rules for this event.
While I do not necessarily agree with the rules, I do realize that this is not a matter that is up for debate.
It comes down to this:
Abide by the rules laid out by the organizers of the event or don't go on the track.
Old Mar 30, 2003 | 07:44 PM
BryanSprinkel's Avatar
Not the case at all. Every school I have participated in, or instructed for has required the "same" safely equipment for both driver and passenger.
Old Mar 30, 2003 | 07:49 PM
BlueR's Avatar
i have removed both my airbags, will that pose a problem?
Old Mar 30, 2003 | 07:50 PM
ZygSpeed's Avatar
Warren already said he won't get in the car with me ... no matter what.
Old Mar 30, 2003 | 07:56 PM
BlueR's Avatar
If you've removed your airbags, I'm assuming you have harnesses and rollover protection?
no, i do not...
Old Mar 30, 2003 | 08:03 PM
ZygSpeed's Avatar
Default Re: Question about Expo Rules (BlueR)
Speaking of which, ... Gina just showed me the banner for "the tent".
Old Mar 30, 2003 | 08:15 PM
lanceh's Avatar
25 Year Member
Default Re: Question about Expo Rules (BryanSprinkel)
same as in same brand? please show me.
Old Mar 30, 2003 | 08:44 PM
97 TYPE-R 312's Avatar
This I have to agree with. This isn't something that can be over looked for a single weekend. This is all about safety. The rules and regualtions are only made for "your" safety and the safety of others around. If I were an instructor and you were strapping up with harnesses and I had a regular seatbelt on my side, I'd be very worried about getting into the car. With more safety equiptment in your car, you will be prone to take the car a little more further than if you hadn't had the equiptment. Your instructor will thank you for consideration on "his/her" side too!
Thanks,
Victor
Old Mar 30, 2003 | 09:00 PM
lanceh's Avatar
25 Year Member
Default Re: Question about Expo Rules (97 TYPE-R 312)
i don't think anyone is questioning the issue of driver side harness and passenger side stock 3pt.
Old Mar 31, 2003 | 03:36 AM
Asahi's Avatar
Nonetheless, I will sleep on it and consult Trey for a consensus tomorrow morning.
Here is my position, George is the power. What He says goes. (Period)
I will speak with George more today on this issue and send out an email if anything changes.
Lance, Seatbelts at a minimum should match. From there a Bucket and a Stock seat are functioning differently and what is the cause for concern. A reclining sparco with deeper bolsters is more likely to get a consideration with the stock seat from what I am getting from things.
Again, I will clarify if something changes.
Old Mar 31, 2003 | 03:51 AM
Same as in same type, not brand. I have been in cars that had an AutoPower on one side and a Sparco on the other. Sorry, I should have been a little more clear. As stated above, the final word in this matter will be posted, or emailed shortly.
