strut squeaks maybe springs?
Old Mar 30, 2003 | 05:33 PM
kent's Avatar
Default strut squeaks maybe springs?
hey guys..i lowered my car on goldline springs. 1.50 in drop. well..my strut/shock squeaks when ever i go up into my drive way or something like that(as in a bump like like). do you guys think its my struts? just need new ones? think it could just be my springs? or dont worry about it?
Old Apr 1, 2003 | 10:59 AM
Agent STFU's Avatar
Default Re: strut squeaks maybe springs? (kent)
Check to make sure the rubber pieces in the top "cup" of your struts are in place, or else the shock will rub the metal and make it "squeak"
Old Apr 1, 2003 | 01:26 PM
whoDAT's Avatar
Default Re: strut squeaks maybe springs? (Syzle)
bump, i need to know also. i have the same problem, except my squeaks constantly. i'm using gc sleeve and collar with skunk coil-over springs (i swapped with my buddy) and they are on itr struts. i have already checked the rubber "cups" and there seems to be nothing wrong. it is extremely annoying and i still can't figure out what is wrong with it... HELP!!!
Old Apr 1, 2003 | 02:51 PM
AcuraEL's Avatar
Default Re: strut squeaks maybe springs? (whoDAT)
BUMP BUMP
need to know too, I have Neuspeed sports with Konis yellows, it used to squeak with stock POS shocks, I puit new Konis in hoping everythig will be in order, damn thing squeaks still on little bumps.
What could this be?
99EX 4 door
Old Apr 1, 2003 | 09:25 PM
cash459's Avatar
Default Re: strut squeaks maybe springs? (AcuraEL)
i have that problem too!! do yo uguys think that it could be because of the old bodies of the cars...mine is a 95 and it does it, how about you....?? my shocks are only 6 months old, so it cant be that...????
Old Apr 1, 2003 | 09:27 PM
ProEater's Avatar
99% of the time this is the problem. especially if you did the install yourself.. take it off and make sure its lined up correctly. a tiny slip and metal will "squeak"
Old Apr 1, 2003 | 09:48 PM
GARBhatch.'s Avatar
i'm using gc sleeve and collar with skunk coil-over springs (i swapped with my buddy) and they are on itr struts. HELP!!![/B]
first of all that just doesn't sound good. Swapping collars just isn't something you should do. They're aren't trading cards. They're major pieces to your suspension.
And the problems could be a few things. 1.)It definetely can be your struts are worn out if a.) they're stock and you've had them on for a while. b.) always check for oil leaking out of the actual shock housing when swapping suspension. Plus check rebound. compress the strut with your hands. then watch to see if it comes up nice and slow like it should.
2.) don't forget to trim bumpstop and dust-boot cover(the plastic piece which can squeek if not put on right due to the fact it actually has metal on the inside) check all these things and 9 times out of ten that will do it.
Old Apr 2, 2003 | 02:32 AM
AcuraEL's Avatar
Default Re: strut squeaks maybe springs? (98Hatch00)
I should"ve have trimmed the dustboot too??
how?
Old Apr 2, 2003 | 10:14 AM
GARBhatch.'s Avatar
how?
A dremel works as does a hacksaw. About down to 1.5 to 2 inches depending on your drop.
Old Apr 2, 2003 | 01:01 PM
AcuraEL's Avatar
but which part I have to cut?
Another idea of squaking source - where the dustboot slides on the shaft, I had to make the hole bigger cauz konis have biggers shafts, but the hole is quite tight, so could this squeak?
and which part I should've cut? bottom rubber boot?
Old Apr 2, 2003 | 09:18 PM
GARBhatch.'s Avatar
bottom? oh no no my friend. The top. This is what stops dirt and grime from getting into your actual strut housing when it goes down. If you use the bottom half that you cut it wouldn't do anything. You must cut it 1.5" down from the top and replace it exactly like you had it on in the first place. I would put some pics how to but i don't have them hosted yet. Sorry. 56k sucks.
Old Apr 2, 2003 | 09:22 PM
GARBhatch.'s Avatar
Oh and if you cut the hole bigger to fit the shaft, that's probably your problem right there. The dustboot cover has a plastic outside but has metal on the inside so it won't get squished if/when the strut compresses on it. You took away the plastic leaving a metal to metal contact. If i was you to be on the safe side, I would check and see if the shaft isn't scratched up at all. This could cause some leaking of the shock after a while.
Old Apr 2, 2003 | 10:46 PM
Mr. Thunderlips's Avatar
Mine squeeks when I turn the wheel, and when I go up and down driveways...But is worse in cold weather. I've always wanted to know exactly what it was. I think It's the 10 year old bushings.
hillbillycivic
Suspension & Brakes
Jul 17, 2012 07:48 AM
sbarmann
Apr 1, 2009 07:56 PM
shibbywhitedude
Suspension & Brakes
Aug 23, 2008 12:26 PM
staticrex
Nov 29, 2005 03:00 PM
Arsenal
Oct 20, 2005 04:35 PM
