What kind of turbo is this?
This is what i got in my drag kit from Ben At importparts.com, he's telling me its a blank turbonetics t3/t4..but i don't agree! plus i have no port off the compressor housing for primary boost readings.
https://honda-tech.com/zerothread?id=458695
the pics are in the type-r section..
[Modified by R-1303, 11:35 PM 3/30/2003]
Can you take pics of the wheels? Hard to I.D. for sure without seeing the wheels.
garret housing don't have the vac nipple on the comrpessor housing...turbonetics does...
it's prolly garret cartridge...
look at the inside of the turbine housing, see if it is a .63 or .48, measure the wheel and count how many turbine wheels there are...
then measure the upper part ( exducer side) of the compressor housing, you'll either get 48mm, 50mm, 54mm, 57mm, or 60 mm...
then let me know, I'll tell you what trim of turbo do you have...
if it's drag turbo, it's 63 AR stage 3 wheel with 54 trim on the comrepssore side, 04E
stan
stan
sorry to go a lil off topic but do you have samco radiator hoses? if so, where'd you get them and how much??
Flamenco-T
Mar 24, 2003 01:03 AM
