how to tell if main relay is toast....
Old Mar 30, 2003 | 12:57 PM
1hottEG6's Avatar
Default how to tell if main relay is toast....
I put a 2k swap in a friends 99 hatch. At the time i had a 97 cx harness converted for the gs-r. Aftter putting it in i realized that the plugs had change, so i figured i could just hard wire some things into the existing plug A under the dash. I wired fuel and a few other things and got the car going- but it kept blowing the VSS fuse and vtec wasnt working.
So i scraped that idea, got a 2k si harness, and use a 2k gs-r ecu with immoblizer removed. I put in the computer tried to start the car wouldnt start for about 15 trys. Fuel pump is coming on, but i know that relay controls spark or injectors or something. Plus it was clicking like crazy
My question is could i have fried the relay when i tried wiring that 97 harness into the hatch?
TIA
Old Mar 30, 2003 | 01:29 PM
dfoxengr's Avatar
Default Re: how to tell if main relay is toast.... (1hottEG6)
its possible, i normally blow fuses, check your mains under the hood, and underdash too
iBear
Apr 26, 2016 07:44 AM
PatrickGSR94
May 18, 2012 05:58 AM
transman46582
Jun 2, 2011 09:10 AM
honda_hackett
Nov 3, 2008 03:56 PM
B16aSir2
29
Jul 30, 2006 10:53 AM
