My custom T/3 t/4 b18c5 boost is done.....
Old Mar 30, 2003 | 09:38 AM
COLORPROS's Avatar
Default My custom T/3 t/4 b18c5 boost is done.....
All i have to do is put the clamps on and its done....Off to the dyno I go..
Old Mar 30, 2003 | 09:47 AM
ModlesSI's Avatar
New User
Default Re: My custom T/3 t/4 b18c5 boost is done..... (COLORPROS)
Nice, its looking good! let us know the numbers...
Old Mar 30, 2003 | 09:55 AM
COLORPROS's Avatar
Default Re: My custom T/3 t/4 b18c5 boost is done..... (ModlesSI)
werd....
Old Mar 30, 2003 | 10:11 AM
Screamer's Avatar
What turob are you using???
Old Mar 30, 2003 | 10:14 AM
COLORPROS's Avatar
Default Re: My custom T/3 t/4 b18c5 boost is done..... (Screamer)
t3/t4 60housing 60-1 wheel and a 48 ar exhuast
Suprdave's Avatar
Hope that manifold doesn't break...
Suprdave
Old Mar 30, 2003 | 10:19 AM
COLORPROS's Avatar
Default Re: My custom T/3 t/4 b18c5 boost is done..... (Suprdave)
Dont worry I braced the hell out of it..But if it does the biatch is going in the trash and a INLINEPRO is going on.
Old Mar 30, 2003 | 10:20 AM
bretx0r's Avatar
expect that manifold to crack soon.
INLINEPRO
[Modified by bretx0r, 7:21 PM 3/30/2003]
Old Mar 30, 2003 | 10:22 AM
COLORPROS's Avatar
Default Re: My custom T/3 t/4 b18c5 boost is done..... (bretx0r)
INLINEPRO
Werd.
Old Mar 30, 2003 | 10:23 AM
alpha's Avatar
Looks good. What kind of numbers do you expect? Also, what radiator and fan are you using?
Old Mar 30, 2003 | 10:34 AM
COLORPROS's Avatar
Default Re: My custom T/3 t/4 b18c5 boost is done..... (0x64)
300 to 350 hp on 10psi somewhere around 400 on race gas and the boost turned up a bit..
The radiator is a fluidine and the fan is a cheap perma cool from Auto Zone and I have it mounted on the front side of the radiator,Its the only thing I am wooried about but a freind of mine has the same set up and as had no problems but will see.My fingers are crossed cuase there is no room behind the radiator.
Old Mar 30, 2003 | 10:35 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Nice ... Stock internally?
Old Mar 30, 2003 | 10:38 AM
COLORPROS's Avatar
Default Re: My custom T/3 t/4 b18c5 boost is done..... (integra707)
yes.Exept the head and I have an INLINEPRO 3mm head gasket kit to lower compresion.
Old Mar 30, 2003 | 12:04 PM
C-Murdock's Avatar
arent you afraid of cooling issues with the civic radiator ?
I wanted to get one for my H22 but some people said I would have cooling problems with daily driving...
Old Mar 30, 2003 | 12:06 PM
DoriDoriboii's Avatar
I had the same problem, my filter would not fit w/ the stock fan so i just ditched the fan and I'm running fan-less for now...other than an overheating problem when I first started the car due to air bubbles, the temp gauge has never climbed higher than where it normally sits...I think as long as u keep moving it should be ok...
I'm still trying to figure out what I want to do w/ the fan situation...
hey, where did you get that reducer coupling for the throttle body and i/c piping connection? i've been looking all over for those
Old Mar 30, 2003 | 12:55 PM
johnisenglish's Avatar
Nice
Hope to see you at Rockingham or Piedmont some time
Old Mar 30, 2003 | 02:08 PM
JDMJDM's Avatar
Default Re: My custom T/3 t/4 b18c5 boost is done..... (johnisenglish)
what manifold is that?
Old Mar 30, 2003 | 02:16 PM
Casey's Avatar
Default Re: My custom T/3 t/4 b18c5 boost is done..... (JDMJDM)
meng/obx/spark racing
Old Mar 30, 2003 | 02:21 PM
SiRkid's Avatar
Default Re: My custom T/3 t/4 b18c5 boost is done..... (C-Redrum)
nice.
an h22 is a little diff than 1.6/1.8L
he will be fine with that rad.
Old Mar 30, 2003 | 06:31 PM
b18c1_eh2's Avatar
Default Re: My custom T/3 t/4 b18c5 boost is done..... (SiRkid)
just wanted to say...
http://www.carolinahondas.com ownz j00!!!
ready for the 6th i hope!!!
Old Mar 30, 2003 | 07:10 PM
BoostedSi's Avatar
nice.
Yup, my friends gsr runs fine with a half sized radiator.
my b16a also has no overheating with the stock half radiator.
Old Mar 30, 2003 | 07:20 PM
Speed PHreak's Avatar
Default Re: My custom T/3 t/4 b18c5 boost is done..... (b18c1_eh2)
Rob you're gay.
Old Mar 30, 2003 | 10:47 PM
b18c1_eh2's Avatar
Default Re: My custom T/3 t/4 b18c5 boost is done..... (Speed PHreak)
only for you baby!
you're just mad i'll be the fastest on teh board soon!
Old Mar 31, 2003 | 02:37 AM
COLORPROS's Avatar
North Carolina Represent..............
Old Mar 31, 2003 | 06:28 AM
TurbothisLS's Avatar
looks very nice
post numbers
