attn: ZC/tech people... need help with starting issues/distributor problems...
Old Mar 30, 2003 | 08:45 AM
TRE_'s Avatar
Default attn: ZC/tech people... need help with starting issues/distributor problems...
well, i put a new distributor on my zc and now it wont start. the starter just cranks and cranks and every once and a while i'll get a nasty backfire. found out i was wrong on the firing order by a little, but i thought that even then it would start just run shitty. i havent had time to see if changing the firing order did anything because my car is at my friends house. but a friend of mine told me that i could have the distributor on backwards basically and that it needs to turn a full 180 deggrees.... he said it could go on TWO ways... but i thought it could only go on one way. so what do you guys think? can the dist. go on two ways? does it sound like i need to turn it a full 180 deggres?
any help is MUCH appreciated.
Old Mar 30, 2003 | 09:09 AM
civbeater90's Avatar
Default Re: attn: ZC/tech people... need help with starting issues/distributor problems... (glowing_rotors)
put your car to tdc-then align the dizzy-turn it upside down and look at the alignment marks.stick it on your head and you shold be good to go.
Old Mar 30, 2003 | 09:21 AM
TRE_'s Avatar
Default Re: attn: ZC/tech people... need help with starting issues/distributor problems... (civbeater90)
i'll give that a try for sure. thanks man.
anyone else have some help?
Old Mar 30, 2003 | 10:49 AM
Ham'ed Hatch
Guest
Posts: n/a
...the starter just cranks and cranks and every once and a while i'll get a nasty backfire ... but a friend of mine told me that i could have the distributor on backwards basically and that it needs to turn a full 180 deggrees.... he said it could go on TWO ways ... go on two ways? does it sound like i need to turn it a full 180 deggres?
your friend is absolutely right. it CAN go on upside down (the gear that slides into the intake cam). it's only slighty offset to one side, and i always have trouble telling which is the correct way. i've done it a few times, and it does EXACTLY as you've described, backfires.
i'm 500% sure. i'd even put money on it
take the sucker off, turn the gear 180 deg, bolt it back on, and i guarentee it'll start right up.
Old Mar 30, 2003 | 02:10 PM
AbaZ's Avatar
Uhm, I didnt know you could put distributors on backwards since they are notiched a specific way to go on, and you would probably have to force it to even stay on?
hmmm
Old Mar 30, 2003 | 07:03 PM
TRE_'s Avatar
Default Re: attn: ZC/tech people... need help with starting issues/distributor problems... (Ham'ed Hatch)
i tried this and it wouldnt go on... so i put it back on the way it orignally was and after about 5 minutes of messing with the firing order it started up. i tried forcing the dist. on after i spun it 180 degrees and it wouldnt go on all the way... anyway, it started right up after we fixed the firing order and messed with the timing.
thanks guys.
[Modified by glowing_rotors, 8:13 PM 3/30/2003]
Old Mar 30, 2003 | 07:08 PM
drjondurst's Avatar
please tell me what firing order you have it set at.. Im having the same problem as you on my DOHC ZC in my 91 Si. it sits there cranking and sounds like its backfiring. This is how I have it set.
Old Mar 30, 2003 | 07:24 PM
TRE_'s Avatar
Default Re: attn: ZC/tech people... need help with starting issues/distributor problems... (drjondurst)
put wire 1 where you have 4, 2 where you have 3, 3 where you have 2, and 4 where you have 1.
Old Mar 30, 2003 | 07:29 PM
blackEF's Avatar
yeah thats cool you figured it out....I expierenced the same problem, and yes the dizzy can go on backwards, it appears to not be in all the way and you can easily tighten it in there. Although before i cranked it over I realized the problem and saved myself from any damage.
Old Mar 30, 2003 | 08:29 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: attn: ZC/tech people... need help with starting issues/distributor problems... (blackEF)
i used to always put the damn thing on upside down. it would slide right in and bolt right up for me. then backfire.
91civicZcSw4p
Jul 22, 2008 01:44 PM
91_LS
Feb 16, 2008 02:25 PM
HondaTomcat
Apr 28, 2005 12:53 AM
NC-B17A
Nov 28, 2002 06:06 AM
kickz
Jan 27, 2002 06:05 PM
