white exhaust smoke
Old Mar 30, 2003 | 07:59 AM
SIK IN DA HED's Avatar
New User
Default white exhaust smoke
a while back... a friend told me that i had white-bluish smoke comin out of my exhaust... mainly during downshifts. recently, i started noticing white smoke from my exhaust during idle after a long drive... or sometimes during short driving around town. my valve seals arent leaking... i checked my plugs spark plugs for signs of oil... none. compression doesnt seem to have dropped since the last test. 150s across the board. coolant levels are fine. any ideas what this could be? could it be my rings finally goin out on me?
i have a boosted b18b in my teg. drag3 kit with 2.5 exhaust.
Old Mar 30, 2003 | 08:45 AM
MiraiZ's Avatar
Default Re: white exhaust smoke (SIK IN DA HED)
sounds like your headgasket
Old Mar 30, 2003 | 09:03 PM
New User
i see no signs of oil leakin from the headgasket. what are some other signs of a headgasket problem?
Old Mar 30, 2003 | 09:07 PM
b16ahybrid's Avatar
here are 8 signs of a bad head gasket......
coolant in your oil, oil in your coolant.....white smoke, poor idle......white smoke.....mixed fluids...white smoke...oh and white smoke ....just a few there are more but i cant remember off the top of my head.........
Old Mar 30, 2003 | 09:57 PM
XxAgentOrangexX's Avatar
I had the same problem in my GSR, we rebuilt the head and i still had the problem with the smoke. compression tested perfect but i was told that if you want to determine if rings are shot to do both a wet and dry compression test, after i did both it ended up showing my rings were shot.
Old Mar 30, 2003 | 10:30 PM
MiraiZ's Avatar
sometimes you can't see a blown headgsasket....if the leak is along the outside edge of the hg, then its visible, but sometimes it could be the perimeters of the cylinders which isn't visible...
Old Mar 31, 2003 | 08:42 AM
New User
Default Re: white exhaust smoke (MiraiZ)
dammit... it might be my rings just like i suspected. ill run more tests as soon as i get a chance...
pepperdk
Honda CR-V & Element
Jun 11, 2015 03:10 PM
KidRuthless
10
Nov 8, 2013 06:53 AM
bpfergu
Mar 5, 2012 05:27 PM
blitzteggsr
May 4, 2004 06:29 PM
Broken Gearbox
Aug 8, 2003 09:00 AM
