white smoke from exhaust
Old 11-06-2013, 07:01 PM
KidRuthless's Avatar
Default white smoke from exhaust
Okay so I have a 97 ek with a 98 gsr (usdm) swap. On occasion I get white smoke from the exhaust, I did a compression test an got 180 on all four cylinders. Also Coolant has been leaking, but from where the firewall and heater hose connects. I also don't have any noticeable leaks around the head gasket.
Also have white smoke at WOT so maybe I am thinking valve seals, but anymore info will be much appreciated!
Old 11-06-2013, 07:08 PM
Chriser0's Avatar
Default Re: white smoke from exhaust
Valve seals would make sense. slow leak when the car has sat and oil needs to burn off when started. Im still learning so someone else chime in please.
Old 11-07-2013, 02:05 AM
Retired Moderator
EsotericImage's Avatar
white smoke could be condensation in exhaust burning off..
at WOT your running pretty rich, you sure its blowing thick white smoke?
Old 11-07-2013, 04:24 AM
purgat0ry's Avatar
Take a video to review everything.
Old 11-07-2013, 04:32 AM
Chriser0's Avatar
When its cold out my car looks like a fright train because of all the steam out of the exhaust. Losing any oil?
Old 11-07-2013, 04:37 AM
Lil Gnome's Avatar
No man. That is simply your exhaust gases condensating in the cool air.
White smoke usually indicates the burning or condensating of water vapor.
Blue smoke is oil being burned.
Black smoke is fuel, usually when you are running rich.
Old 11-07-2013, 04:53 AM
Chriser0's Avatar
Oh I know im not burning oil. I just was telling him that that could be a thing to think about too. and the losing oil would help confirm his suspensions of burning it off.
Old 11-07-2013, 06:05 AM
Lil Gnome's Avatar
Sorry. I did not read fully and thought you were the person who create this thread.
Old 11-08-2013, 06:28 AM
Well Im also not blowing thick white smoke. It happens periodically ill drive shift into second and white smoke will come out through the exhaust and continue when i accelerate after about 2 or 3 minutes itll stop. Also i have no overheating issues.
Old 11-08-2013, 06:34 AM
Joyboy's Avatar
Could be the early stages of head gasket leakage. I would pull the spark plugs and inspect for any signs of coolant being burned. It's best to catch these things early.
Old 11-08-2013, 06:53 AM
I pulled spark plugs and the one in cylinder one has a orangish coloring at at the tip the rest are good also i changed them 5 months ago.
2kdrift
15
02-26-2017 05:58 AM
pepperdk
Honda CR-V & Element
06-11-2015 03:10 PM
FrontwheelENT
24
08-01-2012 07:09 PM
Redprelude98
11-25-2008 10:42 AM
HyperITR742
08-01-2003 08:35 PM
Quick Reply: white smoke from exhaust
