Swapping a 98 type-r in to a 92 VX anything i should know
Old Mar 29, 2003 | 09:31 PM
H23vtecEG's Avatar
Default Swapping a 98 type-r in to a 92 VX anything i should know
i'm getting the obd2-obd1 harness for the ecu. then i'm choping the vx harness to fit the 98 type-r swap.
anything else i should know or sensors i should rewire, any info into converting the distributor into obd-1 and anything else would be great thanx
Old Mar 30, 2003 | 12:27 AM
GTlvr82's Avatar
Default Re: Swapping a 98 type-r in to a 92 VX anything i should know (H23vtecEG)
SEARCH THE NET!!! and you will find things like this www.hasport.com
Old Mar 30, 2003 | 06:36 AM
H23vtecEG's Avatar
Default Re: Swapping a 98 type-r in to a 92 VX anything i should know (GTlvr82)
yeah i allready went there PAL thanx for the info. but they dont say anything on how to convert the 5 wire o2 sensor into 4 wire. since i'm using the obd2 ecu with a harness to fit obd1 ecu clips that are in the car what else do i need to rewire?
Old Mar 30, 2003 | 07:42 PM
GTlvr82's Avatar
BUMP!!!...And on me for being rude.
jonnyc
Mar 15, 2004 06:57 AM
Del_Sol_s
16
Nov 9, 2003 07:24 PM
H23vtecEG
May 18, 2003 05:36 AM
H23vtecEG
Mar 30, 2003 12:31 PM
GReddy SI
Jan 10, 2003 01:51 PM
