putting my b16 together. Problems :(
Old Mar 29, 2003 | 09:16 PM
import-tooner's Avatar
Default putting my b16 together. Problems :(
I have been putting my motor together in the last couple of days. It has been about 4 months since I took it apart and I have run into a problem. There is a thick washer that I am not sure where it goes. I am sure it goes somewhere in the head probably with the valve train. Here are some pics of it. Click on the links.
http://www.skooie.com/images/it/washer.JPG
http://www.skooie.com/images/it/washer2.JPG
sorry the pics are so big. Any help you can give me would be great. Thanks.
Old Mar 29, 2003 | 09:32 PM
HybriDNA's Avatar
Default Re: putting my b16 together. Problems :( (import-tooner)
I have never seen that washer on any b-series head. If im not mistaken that washer looks identical to the one that goes between the crank pulley and bolt. Hope this helps. good luck with your build.
Old Mar 29, 2003 | 09:34 PM
MikeMAN's Avatar
is it a valve seal?
mike
Old Mar 29, 2003 | 09:43 PM
ScottEK's Avatar
Default Re: putting my b16 together. Problems :( (MikeMAN)
fuel rail mount spacer?
Old Mar 29, 2003 | 09:54 PM
Bizarre's Avatar
Default Re: putting my b16 together. Problems :( (beta13)
This is what I think it is too. I will take a pic of one off my b16 and we can compare.
Old Mar 29, 2003 | 09:57 PM
MikeMAN's Avatar
Default Re: putting my b16 together. Problems :( (Bizarre)
im gunna have to go with that also, at second glance
mike
Old Mar 29, 2003 | 10:36 PM
hybridb18's Avatar
um, its either the fuel rail spacer, or the washer that goes on the cam gear bolt
Old Mar 30, 2003 | 02:00 AM
ULTRA911's Avatar
Default Re: putting my b16 together. Problems :( (hybridb18)
its looks more like the fuel rail washer. about the same size.
Old Mar 30, 2003 | 02:42 PM
Default Re: putting my b16 together. Problems :( (ULTRA911)
It's not the fuel rail spacer. I didn't even take my fuel rail off. I really think it goes on the head somewhere.
Corksil
11
Jun 23, 2010 12:13 PM
aut0tek
Jun 2, 2008 07:19 PM
jcintegratyper
Northeast (Sales)
11
Mar 18, 2008 06:15 PM
riceburner700
Jun 3, 2007 06:26 PM
d!zZy
18
Sep 27, 2003 06:16 PM
