Did some more prep to the kaa this weekend
Installed new blingin cobalt rotors
removed some weight from the kaa...its so tiny
out
in
would like to thank david @ R&D and andie @ cobalt friction tech
[Modified by BlueR, 9:19 PM 3/29/2003]
out
in
what brand is that battery, how much does it weigh, and where can I get one?
marc, i took a hammer to all my piggy banks...the money pit ownz me
[Modified by BlueR, 10:19 PM 3/29/2003]
whats the weight on that thing?
what type is it?
Pegasus sells a similar lightweight battery for much cheaper (although its not JDM)
what type is it?
For those who don't need JDM bling:
Dynabatt Battery
IIRC, 5575B is the model with top posts (the model we would need), but check with them to make sure you are ordering the right one.
One caution about the Dynabatt though, it will die if you do not run the car for a few days (in my experience).
Dynabatt Battery
Did you see the price for the Dynabatt?
There really is no better choice for the money, IMHO.
Pegasus Auto Racing:
Part #1169, Weight 11 lbs, 14 Amp-Hrs -- $83
Part #1170, Weight 14.3 lbs, 17.5 Amp-Hrs -- $55
How have they held up?
I think it's interesting to note that if you paint a Dynabatt gray and put T1R stickers on it, it's the same thing as a T1R battery.
Marc -
Looks like your installs went better than ours this weekend...
1. B18C GSR Crank milled .25mm - useless
2. Source another crank Friday
3. Start Assembly on shortblock friday night, leave shop at 2am
4. Saturday morning, pick up where left off, get head assembled
5. 7pm saturday, torgue main cap - crank locks up
6. Strip down to smaller bearings - lock up
7. Try lowering TQ settings - lock up
8. Remove shortblock from engine stand and launch into EF hatchback trashbin
9. 9pm, begin assembly of JDM B16 shortblock - lower CR, but no other choice at this point
10. Its now 12:15 sunday morning...Ian has downed 12 Mountain Dews, Joel is using a cutoff tool on the Mugen pedals for some reason, Daniel is drooling over some lumpy Toda cams and its break time for me.
11. We will be at CMP, albeit with a little less CR and a little less TQ, but should still see 9500rpms
david, i only posted up the pretty stuff
i pretty much broke night replacing the two front lower ball joints
question: why are ball joint press kits not available at the local 7-11
goodluck with the car and race next weekend...see you soon
[Modified by BlueR, 12:52 AM 3/30/2003]
http://www.sbsbattery.com/sla.html
i believe the retail price on the T1R is $135
extra $4 for the paint & sticker, i guess
