Another "Car Wont Start" problem. I have no Ideas left! Help!
Alright, well here's the story. the car has been running great and today i threw some gsr cams in it and thats when the problems started. It would do fine until vtec hit and then it'd hesitate a little and then start to go and then hesitate some more, almost like it was misfiring. Then after driving it for about 10 minutes more it began to just misfire at every rpm and wouldn't rev past about 5k rpms. I was down the street from my house so i come home, check the cap and rotor, both are fine. then i start it again after checking the grounds and it still wont rev. go to the store and buy some new plugs just to make sure and then come home and throw them in and now it wont even start. so i check everything again including the camtiming and still no start. so about 10minutes ago i put the stock b16 cams back in and got the timing perfect again and it still won't start, tried different ecu as well, no codes.
No idea!!!!!! let me know if you have any input!
no spark!! do coils or ignitors give signs such as misfiring at high rpms like i had problems with?
and when it started hesitating bad the tack began jumping up and down about 2krpms worth? coil or ignitor?
RenoRacing
Mar 29, 2003 09:50 PM
