master cylinder and prop valve install..
Old Mar 29, 2003 | 03:59 PM
dfoxengr's Avatar
Default master cylinder and prop valve install..
have a 92 hatch with teg rear discs and the 13/16ths MC, dont feel like bending lines and gettin the boster so i was searching and found that a 91 civic dont know wat trim had the 15/16ths and no booster or line changes, SOOO....went to the yard for something else and was looking around and found some 90-93 tegs, and it looks like they have the same 15/16ths MC with same fittings as my hatch...can anyone help me out with this and if anyone has a pic of a booster so i can see what it looks like...also, whih prop. valve 40/40 will i have to get so i dont have to change lines around.
NEXT ? when installing prop valve and MC, do i just unscrew the fittings an switch them, is there bleeding involved? and any other tips are cool.
Old Mar 31, 2003 | 12:59 PM
dfoxengr's Avatar
Default Re: master cylinder and prop valve install.. (hybridvteceg)
top
Old Mar 31, 2003 | 01:35 PM
92SiB18C1's Avatar
Here you go.
https://honda-tech.com/zerothread?id=364783
Old Mar 31, 2003 | 02:00 PM
dfoxengr's Avatar
Default Re: master cylinder and prop valve install.. (92SiB18C1)
thats where i got the idea to look in a 90-93 teg...and it looks the same...i just need to know how to put it in,..
Old Apr 6, 2003 | 02:02 PM
dfoxengr's Avatar
anyone know? about bleeding it?
Old Apr 6, 2003 | 02:21 PM
d357r0y's Avatar
Once you open any line on your brake system, you have to bleed it. Depending on where
you open it, will also depened on how much bleeding is necessary. Meaning: If you replace
your MC you will have to bleed all 4 brakes. (Don't forget to bench bleed the new MC as it
will probably have air in it also.)
Old Apr 6, 2003 | 03:17 PM
dfoxengr's Avatar
Default Re: master cylinder and prop valve install.. (d357r0y)
thanks...
hytechb20
Feb 14, 2013 05:38 AM
graham412
Suspension & Brakes
Mar 17, 2011 07:43 AM
civicexowner
Jun 18, 2009 03:07 PM
jdm92accord
Jan 31, 2002 08:15 AM
