Widest rubber without rubbing
Isn't a 225 the widest you can go? King Motorsport's ITR they had in that Car & Driver issue had the 16" MF10s with 225/45 or 40 Bridgestone Potenza S-02 Pole Position tires. Does Yokohama make that A032R tire anymore?
The A032R is available from tirerack and costs $135 in a 205/50/15, which is the proper size if you want to maintain your speedometer readings.
