Shift Light wiring, where to hook up rpm signal?
Old Mar 29, 2003 | 10:57 AM
4gen's Avatar
Default Shift Light wiring, where to hook up rpm signal?
if anybody can post pics or even a wiring diagram of where to hook up my rpm signal. My friend said its one of the dist wires, however he cant remember which one. Thx in advance.
Old Mar 29, 2003 | 11:46 AM
4gen's Avatar
Default Re: Shift Light wiring, where to hook up rpm signal? (4gen)
come on guys, gimme some info here
Old Mar 29, 2003 | 01:17 PM
TypeR00_0371's Avatar
www.autometer.com
Old Mar 29, 2003 | 01:27 PM
4gen's Avatar
Default Re: Shift Light wiring, where to hook up rpm signal? (TypeR00_0371)
yeah too bad it doesnt give a vehicle specific wiring diagram, and i dont have a helms for the 93-96 H22a. Thanks for trying.
Old Mar 29, 2003 | 01:41 PM
jc836's Avatar
Ok-the Autometer control box or tach for that matter connects to the BLUE wire on the distributor connector. Find a switched power sources under the dash and all will be good. Some people take the signal at the tach in the cluster, but the best place is at the dizzy. The direction sheet is available either on the website or you can request that Autometer send it to you. Remember that the light requires the control module if you do not have one of their tachs to connect to. (See the catalog online for part #)
Old Mar 29, 2003 | 02:29 PM
4gen's Avatar
Default Re: Shift Light wiring, where to hook up rpm signal? (jc836)
if you could point out the wire in these pics that would be great, thx, and im hoping its one of the wires in these pics, haha .
Old Mar 29, 2003 | 04:54 PM
4gen's Avatar
^^^^bump^^^^
Old Mar 29, 2003 | 05:10 PM
its usually the blue one
Old Mar 29, 2003 | 07:56 PM
sslude's Avatar
i dont see a blue one??
Old Mar 29, 2003 | 09:44 PM
flip1199's Avatar
Default Re: Shift Light wiring, where to hook up rpm signal? (sslude)
there's actually a blue wire up by the passenger side close to where the fuses are. I'll try to take some pics tommorow when the sun comes out.
Old Mar 29, 2003 | 10:23 PM
rjr162's Avatar
Default Re: Shift Light wiring, where to hook up rpm signal? (flip1199)
on most honda's there a blue "tach test" connector. On the 5th gen's it's over on the pass side by the battery. Single blue wire going to a dual plug, hooked into a holder. I know 98 civic's have it on the drivers side.
Old Mar 30, 2003 | 02:08 PM
Default Re: Shift Light wiring, where to hook up rpm signal? (rjr162)
here ya go youngin...
Old Mar 30, 2003 | 03:54 PM
4gen's Avatar
do you mean this wire, sorry for being so persistent, im just worried about splicing into random wires that connect up to my dist. and not making my engine run right. thx.
Old Mar 30, 2003 | 08:51 PM
flip1199's Avatar
its the blue wire that i have the green wire connected to
k3vin337
Mar 9, 2008 07:16 PM
gumby6969
Oct 15, 2005 08:45 AM
clutch33
Jun 9, 2004 04:28 PM
Mike D
May 15, 2003 06:36 PM
4gen
Apr 1, 2003 12:12 PM
