remove braked dust shields w/o removing hub?
Old Mar 29, 2003 | 10:48 AM
lanceh's Avatar
25 Year Member
Default remove braked dust shields w/o removing hub?
any thoughts?
only thing i can thing of are using a screwdriver bit and a pair of plyers but all the bits i have are t00 long.
Old Mar 29, 2003 | 11:15 AM
Dr Pooface's Avatar
Default Re: remove braked dust shields w/o removing hub? (lanceh)
Just undo the screws with pliers, and then cut the shield with snips to remove it. Takes like 1 minute.
Old Mar 29, 2003 | 12:30 PM
Asahi's Avatar
Default Re: remove braked dust shields w/o removing hub? (Dr Pooface)
Vice grips, Tin Snips and a lot of yanking.
I didn't plan to put mine back on.
Old Mar 29, 2003 | 04:19 PM
lanceh's Avatar
25 Year Member
tried just with pliers and they just kept slipping. i'll give it another try some other day.
Old Mar 29, 2003 | 04:25 PM
Willard's Avatar
I just a large pair of slip joint pliers... grab tightly and then tap with a hammer... alti-sieze before putting them back on.
Cut them like this and you can install them once the track event is done.
Old Mar 29, 2003 | 06:53 PM
lanceh's Avatar
25 Year Member
Default Re: remove braked dust shields w/o removing hub? (Willard)
thanks will
Old Mar 31, 2003 | 06:00 AM
6ghatch's Avatar
What would be the problem with leaving them off?
Old Mar 31, 2003 | 06:42 AM
B2FiNiTY's Avatar
Default Re: remove braked dust shields w/o removing hub? (6ghatch)
Only bad thing about leaving them off is dirt and other debris get on your brakes more.
Old Mar 31, 2003 | 06:52 AM
ragejed's Avatar
Default Re: remove braked dust shields w/o removing hub? (B2FiNiTY)
Whats with the silver tape on the ball joint?
Old Mar 31, 2003 | 06:57 AM
Willard's Avatar
Default Re: remove braked dust shields w/o removing hub? (ragejed)
http://store.summitracing.com/defaul...rchtype%3Decat
$17.95 = bling.
Melted rubber = bad.
Old Mar 31, 2003 | 07:01 AM
benmasters's Avatar
I removed mine last weekend. Use MulGrips instead of pliers on the screws, you can be sure they will come off then.
Cant say I have protected the rubber on the ball joints should I?
Old Mar 31, 2003 | 07:17 AM
DutchITR1689's Avatar
I've always wonder if the CV booth and/or ABS sensor won't get overheated at the track due to the hot rotor....
Old Mar 31, 2003 | 07:24 AM
Willard's Avatar
Default Re: remove braked dust shields w/o removing hub? (DutchITR1689)
The CV shaft should have enough air going to it to keep it safe.... but the heat will still be transmitted from the hub.
abs sensor = who knows.
Old Mar 31, 2003 | 07:44 AM
SonicGSR's Avatar
What about the covers on the rear over the ebrake lines?
should we leave that piece on?
giff74
Mar 19, 2005 02:09 AM
ekdriven
Mar 8, 2005 08:00 AM
The Toecutter
Jan 13, 2003 02:36 PM
Dr Pooface
Sep 15, 2002 09:38 PM
