Anybody using the Crane Cams ignition Cap /Rotor external coil setup?
Old Mar 29, 2003 | 10:43 AM
kranked91dx's Avatar
Default Anybody using the Crane Cams ignition Cap /Rotor external coil setup?
I can have one for cheap, for a d16z6 ( I will put it on my d15b, but it's the same head as the z6 )
anybody got some info on it ?? anybody ride with it ??
Wich coil are you running with this setup ?
does it need modification to the actual internal coil setup?
thank's a lot
Kranked
Old Mar 29, 2003 | 12:56 PM
Default Re: Anybody using the Crane Cams ignition Cap /Rotor external coil setup? (kranked91dx)
up
Old Mar 29, 2003 | 04:48 PM
Comon Guys,
any input abouthe Crane ignition cap setup??
or the MSD Cap at least, this would be similar ?
Any setup running on a external coil !!
I ttied the search as usual but everybody knows that it dosn't work, and I need infon on this soon cause I might buy somethime this week.
Kranked
[Modified by kranked91dx, 1:50 AM 3/30/2003]
Old Mar 29, 2003 | 05:15 PM
zCivic's Avatar
Just installed mine. I have a HI 6 with the fireball coil. I used the MSD stem that you use on the factory Diz cap you just drill a hole where the orginal internal coil went and add the stem very e-z. You need to remove the internal coil. Take the pos+ and neg- teminals and run them into the ignition, then it has 2 output wires that go to the coil. run a pos+ wire and a ground- and your done. I dont believe you can use the ignition with the stock coil but you can run an aftermarket coil with out the ignition
Old Mar 29, 2003 | 10:40 PM
Default Re: Anybody using the Crane Cams ignition Cap /Rotor external coil setup? (zCivic)
Thank's a lot!
anybody else using the MSD or CRANE CAMES cap/rotor?
It look like a good way to increase spark energie for cheap.
see ya
Kranked
Old Mar 30, 2003 | 10:17 AM
damn things moved fast today!
still keeping it up to the top !
Old Apr 3, 2003 | 04:54 PM
Brigning this tread out of the dust,
still nobody using modified ignition cap that want to share??
Kranked
siavosh
28
Mar 30, 2010 12:08 AM
CruiseControl
Dec 9, 2005 10:40 PM
-[95cxhatch]-
Dec 30, 2003 02:02 AM
marques4130
May 9, 2003 06:24 PM
turbo sol
May 5, 2003 06:38 AM
