~ES MM Inserts~ Question
Old Mar 29, 2003 | 10:36 AM
day1si's Avatar
Default ~ES MM Inserts~ Question
I just purchased a set of Energy Suspension MM inserts for my 94 VTEC Del Sol and want to make sure I got the correct set.
The ES website says that for all Del Sols it's part #16.1105.
Although aren't the mounts for the VTEC Sol different?
I actually received the MM insert kit part #16.1106, which is for all integras 94-00 and the 99-00 Si. (which are all B-series) So which is the correct kit for the VTEC Del Sol? I emailed ES and they said all the sols are the same, although the guy I got them from and his local distributor where he got them says this is the correct set. So WTF??? I have gotten ill tech support from a company before, so I'm not taking ES's word for bond here.
If anyone has purchased these for your VTEC Sol, please let me know which set you used.
Thanks
James
Old Mar 30, 2003 | 10:08 AM
day1si's Avatar
Default Re: ~ES MM Inserts~ Question (day1si)
Anyone??
Well I did a little research w/ my local Honda dealer and here is what we found.
The rear stabilizer is the same as the SOHC in the Honda database as far as part #'s, although the lower mounts are not.
Now we didn't compare between the Si 99-00 because even if they are the same part, Honda sometimes will give it a different part # for that series of vehicle.
So I guess I will just have to try and install the kit I have and go from there. And my guess will be that the side mounts should work, although the rear may not, and I may have to try and track down just a rear mount from kit 16.1105G
ulieq
Oct 8, 2010 03:21 PM
Contender25
Dec 12, 2006 06:06 PM
Bong29007
Oct 10, 2005 05:52 PM
Fugeeu
Apr 22, 2004 05:49 AM
go_noles28
12
Oct 15, 2002 09:45 AM
