Rack and pinion or Tie Rod?
Old Mar 29, 2003 | 10:20 AM
2camsaam's Avatar
Default Rack and pinion or Tie Rod?
My EJ is not performing suspension wise, the way that it used to.
I turn the wheel and it seems as though the responsiveness it use to have has diminished. I have had an alignment done2 weeks ago.
Is there any way to determine if the rack and pinion is going or has gone or if it is the tie rod?
I have a full threaded coilover kit.
Camber kit
Neuspeed front upper tie bar
Mind you, the car was fine at one point, however, it has gone bad over the last 4 months. I have 195k miles on the body of the car.
Any suggesstions?
Old May 18, 2003 | 12:16 AM
eddie1681's Avatar
New User
Default Re: Rack and pinion or Tie Rod? (2camsaam)
I have an Ek with 132K on the body also. I am having some problems with the suspension dept. also. My car feels very loose when it's moving. I have an manual rack and pinion<------- could that be the problem?
Thanks
Old May 24, 2003 | 07:04 PM
beeboyee's Avatar
Default Re: Rack and pinion or Tie Rod? (b20z)
check if your boots are torn !
Old May 24, 2003 | 07:50 PM
t0p_sh0tta's Avatar
Default Re: Rack and pinion or Tie Rod? (beeboyee)
Worn bushings?
Old May 28, 2003 | 03:32 AM
2camsaam's Avatar
Default Re: Rack and pinion or Tie Rod? (t0p_sh0tta)
I swapped in some brand new tie rods and it cleared up a lot of the wobbliness, it is much smoother on the highway. However, the responsiveness to the wheel has not returned. I can feel the wheels responding to the steering wheel, however, the body, especially, the rear end seems to be slow to keep up.
I have the same suspension upgrades on my car as I did one year ago. Last year, I could steer aggressively and no matter what, there was no lag in response time, now it seems like I am driving an old domestic vehicle.
I will next be replacing bushings throughout the suspension components.
2 questions :
- Should I replace all bushings w/ factory or aftermarket bushings
- Could anything else be causing this poor responsiveness in the chasis
JJ291
Honda Civic (2001 - 2005)
Jul 26, 2013 05:28 AM
jonyi27
Nov 20, 2012 09:23 PM
mattbatson
Feb 23, 2010 05:14 AM
JUN.
Mar 29, 2006 07:46 PM
