RHD Type R?
Old Mar 29, 2003 | 08:51 AM
SinisterCivic's Avatar
Default RHD Type R?
Does anyone know a company that can get RHD Type R's? Im sure this topic has come up before but i got nothing with the search engine.
Old Mar 29, 2003 | 09:43 AM
speed addict's Avatar
Default Re: RHD Type R? (SinisterCivic)
i have recently delt with this issue with Yoshi form J's Garage. it is possible to bring the RHD cars here however the cat has to be changed to a us spec cat and the ECU must be changed to OBD2. the other issue is that you must provide crash testing that satisfies the DOT. basically you have to buy one and crash it. i actually considered doing this and becoming an RI (registered importer) however after the taxes and shipping cost you would pay a few thousand dollars in addition to the modifications and the car itself. for example i would have ended up paying around $22,000 for a 98 ITR. good luck.
Old Mar 29, 2003 | 11:04 AM
Default Re: RHD Type R? (speed addict)
damn that sounds like alot.Thanks for the info. But how does MOTOREX do it? I wonder if they had to crash an R34. That would suck.
Old Mar 29, 2003 | 11:24 AM
CunninLynguist's Avatar
If someone buys a rhd car and has it crash tested does DOT have records of this?
That would be stupid to have multiple owners having the same kind of car sent to have crashed.
Old Mar 29, 2003 | 01:09 PM
92TypeR's Avatar
FSAE
Default Re: RHD Type R? (Rufus)
I was heavily considering having an EVO VI imported last year, and what I found out was most people document the crash results under "Personal Use", and they are not archived with the DOT, and to use them you would have to ask the other owners...not the DOT. That is why MotoRex is pretty much the only importer of Skylines, because they have all the results listed to them, and MotoRex wont let anyone use the results, and in turn they can charge huge fees for the vehicles they bring in.
It wouldn't hurt to ask owners of RHD ITR's for their stats., but if you are only interested in it for the novelty of having a RHD ITR, I would consider just welding on the front clip of the RHD ITR onto a USDM teg, then you wouldn't have to go through the tests.
Old Mar 29, 2003 | 02:18 PM
Default Re: RHD Type R? (92TypeR)
<U>Does any one know the following or where i can find some more info? </U>
When they do the crash tests what condition does the donor vehical have to be in?
They need one donor vehical right?
I remember seeing some list of cars that where ok to import into america. Anyone have that list or a link to it?
thanks .
Old Mar 29, 2003 | 02:23 PM
Resident Evo's Avatar
Buy a JDM ITR front clip. Much cheaper than importing the whole car. Last time I heard, front clips were like...4-7k.
Old Mar 29, 2003 | 04:17 PM
Fat Matt's Avatar
New User
Default Re: RHD Type R? (EBP-Si)
I don't know how much this helps but there is a company called overdrive.com or overdrivejapan.com or something; I sure you could find it if you looked. Nevertheless, they have a brand new 02 ITR for 19k.
HYREV2NR
Mar 22, 2007 10:57 AM
Unreal
Jun 29, 2005 11:34 AM
DISMANTLERGSR
Dec 11, 2003 09:23 AM
Nameless RB26
Sep 9, 2002 02:14 PM
