rear disk swap done
i finish doing my rear swap, but theres one problem my e-brake dont work.what should i check to see if the caliper is good or not. everything works in it fine but like i said the only thing not working is me e-brake. it brakes fine when driving.any info would be appreciated thanx
check the slack, i installed type-r brakes on my friends 92 civic and all i had to do is tighten the e brake. there is a small lid that pops off in the back of the center console and 2 nuts to adjust it just turn them.
if that doesn't work check the connection at the brake.
91_hatch_si
Apr 28, 2003 05:21 AM
