Swap Near Pics and Comments Needed Anything that would Help During B16a SIR II in a 4th GEN DX...
Old Mar 28, 2003 | 11:24 PM
bossman032's Avatar
Default Swap Near Pics and Comments Needed Anything that would Help During B16a SIR II in a 4th GEN DX...
Modified by bossman032 at 8:26 AM 12/28/2003
Old Mar 29, 2003 | 07:00 AM
plastik462003's Avatar
Default Re: Swap Near Pics and Comments Needed Anything that would Help During B16a SIR II in a 4th GEN DX..
it sounds like u are in good shape, check to see if your ecu is the right on u need, also replace the hoses,belts,and anything else that needs replacing
Old Mar 29, 2003 | 06:29 PM
SEA Hag's Avatar
How come you have the 1st gen valve cover? I thought Sir 2's said VTEC bigger than DOHC. I know they can be switched,I was just curious.
Old Mar 29, 2003 | 06:48 PM
civicmark's Avatar
i was thinking the same thing...?
Old Mar 29, 2003 | 09:59 PM
pokemon's Avatar
Also has a 1st gen driver side motor mount? Hmmm...even though the dist and the IM is sir2 maybe you got jerked? ;x
Old Mar 30, 2003 | 12:00 AM
bossman032's Avatar
hello everyone,
the valve cover was replaced because the real valve cover was fucked up!! cracked
Old Mar 30, 2003 | 12:03 AM
bossman032's Avatar
its Grey Plug Dist!!!
can you explain more..?
Old Mar 30, 2003 | 12:06 AM
Stupid Ass's Avatar
Im drunk right now, but I believe OBD-1 is grey plugged... I saw that you said you had the proper harness/wiring, so their shouldn't be a problem.
Old Mar 30, 2003 | 12:29 AM
bossman032's Avatar
Jason Nucom
Dec 2, 2012 09:42 AM
crxnj
Apr 7, 2006 05:42 PM
littledan
Sep 14, 2005 11:20 PM
EIT_certified
17
Mar 9, 2004 05:46 PM
