Off the Wall Timing after dizzy fix
Old Mar 28, 2003 | 06:37 PM
EF8_SiR's Avatar
Default Off the Wall Timing after dizzy fix
Car: B16A CRX
Recently I jsut got my dizzy replaced with one from a G1 Teg LS (sawed off one leg, etc); anyways, it runs
The only problem is that once I took it for the first drive it felt really slow and stilll does. My first guess was probably my timing was messed. I take a timing gun and check it out.
TDC mark was left of the block arrow and my 3 pts of (14,16,18) are waaaay down on the left side. So WTF happen here??? My dizzy has been advanced all the way and now I just slapped on an ignition timin controller and cranked it up another 15*. The pulley marks got a bit better but the engine block arrow ain't anywhere close to where i want it to be.
I was reading up on the timing resetting mechanism (jump the wht/grn and bwn wire), and am considering to try it but dunno if there's anything I should do b4 i do jump it.
1) Does anyone know why my timing marks are so F*cked up?
2) Can anyone explain to me the operations behind the timing reset thing?
Thx
Old Mar 28, 2003 | 09:51 PM
ScottEK's Avatar
Default Re: Off the Wall Timing after dizzy fix (EF8_SiR)
Did you check both dizzys with the caps off to make sure that the rotor is lined up with plug 1 on both at the same spot. Your timing belt could be off a tooth too, I believe that would cause that.
Old Apr 8, 2003 | 07:07 AM
EF8_SiR's Avatar
Yep, it was the timing belt. My intake cam was off by 2 teeths. After getting everything realigned my car flies again.
Thx man. For some stupid reason it never occured to me that it could've been the cams - I was pinpointing it to the ignition timing the whole time.
Pancho2193
Mar 13, 2013 10:38 AM
80strucksrule7
Jul 31, 2012 02:58 PM
dem0nk1d
Jun 27, 2012 12:39 PM
northemt88
Mar 15, 2008 12:57 AM
Hybridize
Oct 31, 2003 11:31 AM
