Skunk 2 OBD1 ECU?
Old Jun 17, 2001 | 03:55 PM
Type R's Avatar
Default Skunk 2 OBD1 ECU?
I heard that skunk2 sells a reprogrammed OBD1 ECU for most cars? I was wondering if they can program it for my car and i also need the adpater harness..
Thanks
Old Jun 17, 2001 | 03:56 PM
Type R's Avatar
Default Re: Skunk 2 OBD1 ECU? (Type R)
i forgot to mention i have a 01' itr.
Old Jun 17, 2001 | 03:58 PM
t's Avatar
t
They only do it to a OBD1 civic ecu.
Old Jun 17, 2001 | 04:03 PM
Type R's Avatar
Default Re: Skunk 2 OBD1 ECU? (t)
i though they can reprogram as well as sell you a obd1 ecu ? o well i should just look for a obd1 gsr one...
Old Jun 17, 2001 | 04:35 PM
Spyglass's Avatar
New User
The skunk program works for both b16's and b18's. Talk to Kenji, he might have p28 with the skunk program, he will for sure have a harness. Kenji is also very easy to do business with, highly recommend talking to him. I recommend the ecu also, I was very pleased with its performance.
Old Jun 17, 2001 | 04:51 PM
Black SVT's Avatar
Default Re: Skunk 2 OBD1 ECU? (Mr. Green)
I am with Mr.Green.Contact Kenji211@gte.net.He will be able to get you what you want.
Old Jun 17, 2001 | 05:17 PM
Type R's Avatar
Default Re: Skunk 2 OBD1 ECU? (Dc2k-specR)
thanks! can someone explain the skunk2 program for the b18 engine? like when does vtec kick in, rev limiter? i will email Kenji.
thanks
Old Jun 17, 2001 | 06:02 PM
Michael Delaney's Avatar
OBD1 D16Z computer can be converted to be used in an ITR.
Old Jun 17, 2001 | 07:32 PM
ninjaman's Avatar
New User
skunk actually has two variants of their program. Both have a rev limit of 9000, but the newer of the two kicks in VTEC a bit earlier (5200 instead of 5600 I believe - but you may want to verify these numbers), which keeps the torque curve more linear.
Old Jun 18, 2001 | 12:38 AM
sgT's Avatar
sgT
Default Re: Skunk 2 OBD1 ECU? (ninjaman)
I am currently testing one of those.
It appears to do a good job and the car feels pretty good.
However, one MAJOR problem I have is that it is open loop
meaning while cruising it doesnt correct the fuel mixture.
And in my situation where I am using 310 cc injectors at 75psi
i have JUST enough fuel for WOT, but when cruising and at
idle the car runs INCREDIBLY rich and fouls plugs quickly.
Gas mileage is decent but I am almost always on the gas as well.
Others may not find gas mileage to be as good.
Gee3
Mar 1, 2005 04:33 PM
F00LI0
Jul 18, 2003 12:36 AM
Tommy_Gunns
Nov 25, 2001 05:40 PM
