picture request of 99-00 si front LCA's
Old Mar 28, 2003 | 12:13 PM
mugen76's Avatar
Default picture request of 99-00 si front LCA's
i have a 2000 civic hatch here with stock dx front lca with a jim fab traction bar mounted to the bolts like this:
i wanted to add a ctr sway bar and it also came with ctr lca's (b/c of the endlinks) but my jim fab traction bar will not mount to the lca anymore b/c those two bolts aren't on the ctr lca. do 99-00si's have the front bolts like the one in the picture? i need an lca with BOTH swaybar endlink and jim fab mounting bolts.
summary:
stock DX lca: jim fab mounts yes, sway endlink mount no
CTR lca: jim fab mounts no, sway endlink mount yes
Si lca: sway enlink mount yes, jim fab mounts?????
[Modified by mugen76, 1:17 PM 3/28/2003]
Old Mar 28, 2003 | 12:20 PM
mugen76's Avatar
Default Re: picture request of 99-00 si front LCA's (mugen76)
can someone please look under their 99-00 SI to see if the front side of your front LCA has those bolts? thanks in advance.
[Modified by mugen76, 1:21 PM 3/28/2003]
Old Mar 28, 2003 | 12:27 PM
kommon_sense's Avatar
look at the schematics on http://www.hondaautomotiveparts.com
Old Mar 28, 2003 | 12:34 PM
mugen76's Avatar
Default Re: picture request of 99-00 si front LCA's (kommon_sense)
thanks.. i didn't think of that.. from the looks of it..
prob not huh..
Old Mar 28, 2003 | 12:36 PM
mugen76's Avatar
got it.. i think the 99-00 EX will have what i need:
Old Mar 28, 2003 | 01:22 PM
racecarpete's Avatar
here is the breakdown, the DX-EX models have 2 piece front LCA's so you can run an EX front sway bar setup. The EX sway bar is 22mm. The CTR/SI sway bar is 26mm but the front LCA's are 1 piece so therefore your jimfab setup won't work. It's up to you what you want to do. Later
H22Stew
Suspension & Brakes
Mar 29, 2008 01:33 AM
deviant1
14
Aug 22, 2005 05:19 PM
2 point 0
Jul 5, 2004 10:22 PM
SW20 MR2
58
Mar 20, 2003 09:19 PM
