help stripping a rex
Be really gentle about the door trims and the hood is easy there are two 12mm bolts on each side of the hood where it lifts up. and the fender is kind of a pain if you dont remove your bumper but there 10 mm bolts near the fender and door. Then take off all the plastics around the inside then there are a bunch of random bolts on the other end.
chris
chris
actually take off all the skrews then i believe you grab the botom of the trim more towards the door latch and just start pulling but with a wiggle, not a soft wiggle but more of a earthquake like wiggle and one after another the clips will pop right out
o also, this car is a new one at the junkyard, but the hood pop latch inside is broken so how do i pop the hood, gankin the hood too, same color as mine w/ no dents at all.
its si red, looks like someone just didnt want it anymore, its got a d16a in it, no swap or turbo or anything. but its in great shape, i just want to get to it before the mexicans do, haha
Does anybody know where to buy those trim clips? I checked at honda and you can only buy them with a new trim wich is 60 bucks.I really need these mine were all broke and somebody used 3m two sided tape to put it back on.
http://www.hondaautomotiveparts.com under category "side protector"
-kev
