EK rear disc conversion (have searched already)
can anyone tell me what all is needed to do a rear disc conversion on an EK coupe? i know roughly how to do the rdc on a crx but need a little more info on performing this on my 96 dx coupe. what vehicles can the trailing arm and rear disc assembly come off of? do i need to change the ebrake cables? thanks in advance.
oh, and do yourself a favor and get a bigger master cylinder and brake booster and a 4-wheel disc brake prop valve.
[Modified by YumVTEC, 6:54 PM 3/28/2003]
the e-brake cables are tricky, you have to slide the brackets around on them so they line up with the mounting points on your car. other than that everything is bolt up.
can someone tell me the difference between the ebrake cables on a car with and without disc brakes???? considering length i would think you could make my stock ones work??? probably wrong in thinking that but who knows.
also, can someone tell me how to pull up PMs, cause i accidentally closed one that just popped up, and i would like to look at ones i was recently talking on to get some information i didnt write down.
go to my profile up top, then scroll down and you will find you instant message history, click the name to see the message, click open im to write back
i havent got the brake comversion yet. when i do get it though i was wondering why i couldnt just use the ebrake cables that are already on my care. i am sure the way they connect to the brakes is a little different but isnt there a way to convert the cable connections over???
also the car i have in mind to get the conversion off of happens to be a sedan, so i am sure the ebrake cables would be too long.
[Modified by BurntRice009, 2:59 PM 3/28/2003]
how hard is it to change out the MC and booster? and where can i get the prop valve from the Si considering there arent any wrecked around here.
ok another question...
considering i am not racing and my brakes are strong enough but could use a little upgrading. other than the looks of rear disc conversion...would i just be better off changing the MC and booster, as well as new rotors calipers and pads????
If you want to upgrade braking, I would upgrade the fronts first. EX/SI/GSR fronts with the larger booster/mc.
[Modified by kommon_sense, 3:09 PM 3/28/2003]
http://www.evanshondaspecialist.com
thats where i got mine from.... and i bought a si prop valve from honda brand new for 80$, paid 300 for complete swap from a 2k1 teg...everything bloted right on...prop valve is hard to put on...but other than that...not much else..
campbuds
Jul 1, 2006 12:55 PM
Adrenaline_Racing
Nov 9, 2005 04:24 PM
powerslide360
Mar 20, 2005 07:30 PM
