Went to Dyno 2 day
Old Mar 27, 2003 | 09:27 PM
Oval55rag's Avatar
Default Went to Dyno 2 day
I pulled 165.4hp at 8350rpm and 109.9tq. On a Dyno Jet at Mustange Ranch in San Jose. Dude rushed the F**k out of me. So, I just adjusted the cams.
Stock B16a bottom end (compresion 1-175, 2-170, 3-180, 4-175)
(pnp head, matched ported skunk manifold and matched ported cheap *** Ebay 4-1 header) did my self
CTR cams w/ OBX cam gears +3 int, -1 exh
ITR intake springs and B16 int. spring for exh. w/ skunk ti-retainers
AEM fuel rail and B&M fpr and gauge 42psi
APEX VAFC and mugen chip pr3 (did not touch vafc besides vtec set at 5400)
home made 3" cai and getto *** 2.25 exh. to a magna flow muffler w/ punched out cat
Old Mar 27, 2003 | 09:28 PM
Oval55rag's Avatar
Default Re: Went to Dyno 2 day (Oval55rag)
Scanner does not work so I will post pics 2morrow
Old Mar 27, 2003 | 10:00 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Nice #'s. We are very close mod wise...im using ITR cams though and my head is not P&P'd. You should seriously consider milling your head .020 - .030, with a .020 mill you are looking at around a 10.8 compression ratio and i would be willing to bet you will be deep into the 170s at that point. What are your plans for the bottom end?
-Todd
Old Mar 29, 2003 | 07:42 AM
Oval55rag's Avatar
I am building a gsr short block. CTR pistons, shot peened rod w/ arp bolts, and a balanced crank. Do you think a lightened flywheel will be good for the 1/4 mile.
Old Mar 29, 2003 | 08:18 AM
blah13's Avatar
Lightened flywheels are good, esp since youve got some decent mods goin. Jus keep in mind the lighter you go the more tedious street driving is.
Suck my DX
76
Jun 19, 2005 07:23 AM
Suck my DX
Jun 14, 2005 03:33 PM
toda_eg6
Feb 23, 2005 10:03 PM
NeOh 2ning
Aug 11, 2004 10:54 AM
Mike K
Dec 14, 2001 09:16 PM
