Is this a good price for LS/VTEC buildup.
BLOCK:
$1,742.23
1.rebuild block with new SIR pistons with rings/pins
-rebore/hone block
-wash oil/water passages
2.polish crankshaft
3.press out/in rods
4. re-size rods
5. new oil pump
6. new gaskets and seals
7. new bearings
8. new water pump OE
9. new timing belt OE
10. Disassemble/Assemble Engine
Cylinder Head:
$377.00
1.Machine Cylinder head for LS-VTEC conversion
-parts, labor included
2. New Head Gasket OE
This setup would allow me to run 91 octane and not ping. I currently have a b18b and was planning on doing this setup. Do you guys think it's a good price?
$1,742.23
-rebore/hone block
2.polish crankshaft
3.press out/in rods
4. re-size rods
5. new oil pump
7. new bearings
Cylinder Head:
$377.00
well from a view point of another Engine builder... I think its a little too much, but for comparison, our high compression LS-CTR/ITR piston blocks are about $1300. only thing diff that I see is that they have added the water pump and timing belt. other than that, its pretty much the same parts on the block that we do. on the head, we only charge about $235 or so for the LS/VTEC conversion on the head with oil lines /fitttings, resurface head, and new head gasket.
If the price includes labor in putting it all back into the car and installing the head to the block, etc. then thats a pretty good price.
[Modified by exospeedAMcrx, 2:05 AM 3/28/2003]
A shop called LDL is doing in it. The price only includes assembly. It would be more if they put the engine in the car.
hmmmmmm.....never heard of that shop....do they do good work?? where are they at?? cost seems pretty steep to me...then again, i'm in socal where parts are cheaper....so...
Sorry I have a stupid newbe question......
What is an LS/VTEC conversion?
KustomCrx
Sep 13, 2004 10:18 PM
DOMKID
May 14, 2004 07:25 PM
