mounts dont line up on D15 swap
Old Mar 27, 2003 | 07:09 PM
BADGUYNY's Avatar
Default mounts dont line up on D15 swap
A friend of mind just swapped in a d15 vtec into his 90 Si and the rear tranny mount doesnt line up. Any reason why it doesnt line up and how can I correct it
Old Mar 27, 2003 | 10:15 PM
Louie B.'s Avatar
Default Re: mounts dont line up on D15 swap (BADGUYNY)
you need to put the si's mounts on the new engine, including the part that attaches underneath the timing cover.
Old Mar 28, 2003 | 11:48 AM
BADGUYNY's Avatar
Default Re: mounts dont line up on D15 swap (thumpu77)
I am using the si mounts and the rear tranny mount doesnt line up
Old Mar 28, 2003 | 12:36 PM
Redline130's Avatar
Could be that the rear mount is bolted into the wrong holes on the rear crossmember. Also, what transmission are you guys using? I'm assuming the cable one, right? Are the other mounts aligned?
Old Mar 28, 2003 | 04:02 PM
BADGUYNY's Avatar
Default Re: mounts dont line up on D15 swap (Redline130)
Its a Si tranny yes all the other mounts line up except for the rear tranny mount
Old Mar 28, 2003 | 05:13 PM
civicdragger818's Avatar
try moving over the rear tranny mount just for ***** to see if it will bolt up then
esean93
Oct 12, 2008 03:29 PM
CivicUtah
Sep 18, 2007 02:17 PM
Del Sol on Steroids
Apr 13, 2007 04:23 PM
spyderracing
Aug 13, 2004 10:01 PM
KevronsEG
Apr 30, 2003 09:48 AM
