Pre MPFI swap Qs (search disabled)
OK so I have been pooring over the MPFI swap for a while now and Ive done it in my head alot. But I still have some questions. As for the cyl. sensor wiring= I know that you move c1 - b10 and c2 - b12. There is no pin in the b12 hole. Where can I get an extra one from my current harness? And what do you do with the leftover wires from b10-b12? I also dont want to run the wires through the current harness. I want to run an individual wire to to each location that has to be changed. Is this ok? Where can I power up my injector resistor form? In the Hondatunning mag it says that I can get power from a Lrg. yellow wire w/ a black stipe on the the drivers side shock tower. Is this correct? So I just cut it and run it to the red wire on my injector resistor? Other then that. everything is clear. Thanks
Blaze
[Modified by Blaze45, 12:42 AM 3/28/2003]
Blaze
You connect blu/grn and blu/yel to where c1 and c2 used to be. The larger yel/blk is the feed for the inj. resistor box. Also you have to switch the two outside wires on the TPS. Good luck
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Someone needs to come out with a mpfi swap kit .....it would sell like hotcakes.....that gives me an idea....be quite....everyone can hear you....lol....
I seem to recall someone on this board making converted engine harnesses so all you have to do is the changes at the ecu, but that was some time ago and I don't remember who.... possibly blown90hatch???
CPreston
Feb 11, 2011 02:38 PM
crxallmotorworks
Jun 16, 2004 11:30 PM
ham
Jun 15, 2004 11:55 AM
