???? on shocks and springs
Guest
Posts: n/a
B18C5?! you gots ta be kidding us foo! there's no way dat mota will fit in an 86! that ****'ll drop tha nose to tha ground y0. can't be done dude. nope. huh uh. negative cappy tan. just not gonna happen.
btw...you have torsions/f and springs/r.
The b18c5 will fit, it may require moving the raditor a little.
Not my car but notice the room there?
Don't put down 1st gens, the part market maybe suck but these cars are great.
OPM Motorsports( http://opmmotorsports.com ) has everything you need... bigger torsion bars, Koni/Tokico's, rear springs..
Front has Torsion bar set up....
The above link has EVERYTHING....
Cal OPM and talk to them... they can recomend EVERYTHING you need... you might have to wait for Tbars because there having a problem with getting them... have a set of 23mm(stock is 19MM) I got way before the shortage...
I would recomend NO LESS then a 27 MM tbar.. which will be harsh as **** for street use.. but the weight will offset that with a b series....
The rear... OPM has coil overs... but Ground control sells the for less... I would as for a 350LB spring in the back....
Shocks... You got a ton of choices.... I got a set of unused Tokico Illuminas you can buy off me for less then what you would pay for them on OPM or ground controls sites.
i know Mr.S!!!!! the peps say that it don't fit are the 1's who want this motor but can't aford it. or just hate it or somthing cuss i know it fits lo.l i seen it befor!!! LOL LOL
Guest
Posts: n/a
Misinformation. The swap WILL work. The B18C5 is the same size as a b16, only 7 or 8 mm taller.
this isn't my car anymore, i traded it to a member on the board. but i don't think he'd mind me posting pics of it when i had it...
to you for thinking you're sooooo cool cause you're supposedly getting a typeR motor. admit it, you just want it to back up the CIVIC TYPE-R stickers already on your car! heh.
and for christ's sake, stop typing "peps"! if you're going to be ghetto, spell it right, it'd be <U>PEEPS</U>.
Mr_Moos
Oct 10, 2008 04:16 AM
JinMTVT
Jul 4, 2001 10:01 AM
