Couple of pics
Can someone please tell me how to reduce pic size
Currently 215whp with stock exhaust. I drove it for the first time in a while today..What a difference from the s2k...Nice and raw
Spoon 421, Carsound cat, Toda flywheel, Exedy clutch, Vafc, JRSC 5.5 psi, fuel pump, BTC, racing plugs(forgot which ones since we've changed them a lot), new wires, distributor, many other things related to the JRSC that i can't remember, and much tuning. I still need an MSD ignition or something because the car runs very rough when cold because of all the fuel. I also need an exhaust and a better intake since that one is the modified stock with stock filter. After that and leaning it out a little and i should be at about 225 or better..Not bad for 5.5 psi. The car only has 30,000 miles on it because i never drive it.
dis mah ride!
[Modified by honda itr, 4:29 AM 3/28/2003]
, but where in Arizona are you located? i've never seen you around and I've lived in the phx area and now located in the tucson area.
