Which JRSC to fit on B17a* from 93 GSR?
Old Mar 27, 2003 | 01:19 PM
Bigjussin's Avatar
Default Which JRSC to fit on B17a* from 93 GSR?
Hey all, will all accessories work when the kit is installed on the da chassis?
thx
Old Mar 27, 2003 | 03:04 PM
CRVRX's Avatar
Default Re: Which JRSC to fit on B17a* from 93 GSR? (bigjussin)
You will need either a B16A kit or a Type R kit, Not sure about it fitting the car.
Old Mar 27, 2003 | 03:44 PM
QCKGSR's Avatar
Default Re: Which JRSC to fit on B17a* from 93 GSR? (CRVRX)
yea
Old Mar 27, 2003 | 04:05 PM
UberTeg's Avatar
it will NOT fit in your DB/DA unless you relocate the master cylinder!
Old Mar 27, 2003 | 07:21 PM
G2turbo_terror's Avatar
Default Re: Which JRSC to fit on B17a* from 93 GSR? (UberTeg)
exactly!
Old Mar 27, 2003 | 07:53 PM
jabroni95gsr's Avatar
Default Re: Which JRSC to fit on B17a* from 93 GSR? (G2turbo_terror)
if you get the type r kit, make sure you upgrade the nose pulley to the gsr one which is 4", the R one comes with a 4.2" which is good for a little less boost since the R has more comp stock.
Old Mar 29, 2003 | 09:58 AM
Bigjussin's Avatar
Default Re: Which JRSC to fit on B17a* from 93 GSR? (jabroni95gsr)
thanks guys, anyone have any experience with the OBX tubular turbo manifolds? will they fit the da chassis?
thanks again
Old Mar 29, 2003 | 10:08 AM
UberTeg's Avatar
thanks again
pretty much any turbo manifold will fit it. SOme require you to switch to a half-style radiator tho (and lose ac).
Red_ED8
Dec 5, 2009 02:43 PM
WVHondaHatch
Dec 23, 2006 05:24 PM
Cheeks153
May 1, 2003 01:48 AM
Spoonvtec
Nov 4, 2002 07:05 PM
Cyrio
Nov 7, 2001 09:06 PM
