What's a good HALF size aluminum radiator for a CRX?
Old Mar 27, 2003 | 06:58 AM
Ri5e's Avatar
Default What's a good HALF size aluminum radiator for a CRX?
I'm looking for a new radiator, the stock one cracked at the top. I found the fluidyne one but it's a full radiator. I'm removing the A/C so I'm only looking for a half sized one. Will the 92-95 Civic Fluidyne radiator (half size) fit into the CRX?
Old Mar 27, 2003 | 07:03 AM
89 CRX SI's Avatar
Default Re: What's a good HALF size aluminum radiator for a CRX? (4 Stroke)
get a civic half size one for fluidyne....
Old Mar 27, 2003 | 07:05 AM
Ri5e's Avatar
will it drop right in? or will modifications be required? also are you tlking about the 92-95 year radiators?
Old Mar 27, 2003 | 07:08 AM
yellowhonda88's Avatar
its taller than the stocker, so you either have to lean it back or cut out the supports on the hood above the radiator cap...I am dealing with that situaltion now, trying to find a JimFab like set-up tat will allow me to run a 93 small radiator fitting stock like the Place Racing cross member but i want to eliminate the radius rodd bushings....
Brett
Old Mar 27, 2003 | 07:55 AM
Steve91's Avatar
Unless you get an aftermarket cross memeber, the 92-99 radiator will fit like ****( I know, I've done it). It's way too tall. Get a Place Racing cross member and you'll be in business.
Old Mar 27, 2003 | 08:03 AM
unstopabledj's Avatar
Default Re: What's a good HALF size aluminum radiator for a CRX? (Steve91)
anyone have a pic of this place racing crossmember? im looking to get a half size radiator as well..thanks
Old Mar 27, 2003 | 09:05 AM
FOrSfEd's Avatar
Default Re: What's a good HALF size aluminum radiator for a CRX? (unstopabledj)
I ordered mine the other day, here is a topic about it, and I orderd mine from Afterhourzracing. https://honda-tech.com/zerothread?id=423580
Lee
Old Mar 27, 2003 | 09:39 AM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: What's a good HALF size aluminum radiator for a CRX? (FOrSfEd)
you can use the stock radiator for a good couple months. get your turbo and motor put it. I am using my stock radiator for a couple months. You know the setup I have in my crx. then go with the 92-95 Civic Fluidyne Radiator and get a z10 crossmember and be happy.
Old Mar 28, 2003 | 09:47 PM
customx_'s Avatar
New User
i heard the dodge neon radiators fit and they are half size. i just forgot what years
Old Mar 28, 2003 | 10:30 PM
WuShu's Avatar
New User
Default Re: What's a good HALF size aluminum radiator for a CRX? (usdmRob)
newer neon rad. ill see if i can take pics of mine, clears up a ton of room.
Old Mar 30, 2003 | 07:48 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Default Re: What's a good HALF size aluminum radiator for a CRX? (HondaCRX)
fluidyne....all the way...if you got the cash....
Old Mar 30, 2003 | 08:35 AM
SFWD tC's Avatar
Default Re: What's a good HALF size aluminum radiator for a CRX? (dgonzals)
The C&R radiator comes with it's own fan and save space, unlike the stock fan.
Old Mar 30, 2003 | 08:48 AM
civbeater90's Avatar
Default Re: What's a good HALF size aluminum radiator for a CRX? (ChopTopSi)
bro get a custom pwr one.i had them make me one that has the same surface arear as a 92-95 raditator.its about 3 inches thick.it was cheaper than a fluidyne i think.if you have any questions IM me
Old Apr 2, 2003 | 02:13 PM
clarkBAR's Avatar
Default Re: What's a good HALF size aluminum radiator for a CRX? (civbeater90)
HondaCRX...... did you ever get picks of your radiator? Are you possitive it will fit in 88-91 crx?
Old Apr 2, 2003 | 03:02 PM
turbohf's Avatar
Default Re: What's a good HALF size aluminum radiator for a CRX? (clarkBAR)
here is my setup:
Old Apr 2, 2003 | 03:41 PM
crx(gator)'s Avatar
Default Re: What's a good HALF size aluminum radiator for a CRX? (turbohf)
what radiator and x-member are you using?
Old Apr 2, 2003 | 03:59 PM
clarkBAR's Avatar
Default Re: What's a good HALF size aluminum radiator for a CRX? (crxgator)
turbohf.............what radiator is that and how was the install?
Old Apr 2, 2003 | 04:20 PM
technine's Avatar
Yeah, what radiator is that. Looks like a good radiator and easy to install.
Old Apr 2, 2003 | 07:19 PM
*Boostwerks*'s Avatar
http://www.absoluteradiator.com
Get the NON-VTEC Delsol radiator. It is made by CSF, all metal, and is dual core. It's what I'm using, and it works great! And at only about 110 bucks, you can't beat it!
Here's a pic...
Old Apr 2, 2003 | 08:25 PM
turbohf's Avatar
Default Re: What's a good HALF size aluminum radiator for a CRX? (technine)
its from a 75 Civic
here is my little 'write up'
fits ok, there is nothing holding it in or in place besides the radiator hoses but works pretty good. would work a little better if that radiator fan sensor wasnt on the bottom of the radiator (its on the back of the block on a CRX/Civic), i bought a plug for it but im being lazy. plus the coolant drain **** is on the oppisite side. im using the stock CRX crossmember for now... fell free to ask more questions if you have them...
[Modified by turbohf, 5:26 AM 4/3/2003]
Old Apr 2, 2003 | 08:35 PM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
can this be done on a stock d15?
Old Apr 3, 2003 | 03:28 AM
clarkBAR's Avatar
Default Re: What's a good HALF size aluminum radiator for a CRX? (MR.RED'89)
Bryson.......will that radiator fit even w/ the stock cross member? I see an after market one in the picture.
Old Apr 3, 2003 | 06:10 AM
I'm sure it's possible, but I'm sure it will need to be hacked up pretty good to fit at all. Even with my JimFab, I had to cut several places out of the hood for clearance.
If you want a half size radiator that fits without most of the hacking, go for the half size neon. They use the same mounting points as the CRX, but it's half size. The only reason I didn't is because I couldn't find a cheep place that sells them brand new.
Old Apr 3, 2003 | 09:13 AM
scratchline20's Avatar
A friend of mine used one from a 96 neon when he put in his b16.
Old Apr 3, 2003 | 09:54 AM
Ri5e's Avatar
Default Re: What's a good HALF size aluminum radiator for a CRX? (scratchline20)
hmm..half size neon fits into a crx, with the oem crossmember ? interesting..
