hood wont open!??
Old Mar 26, 2003 | 09:45 PM
Toptul_Honda's Avatar
New User
Default hood wont open!??
my hood used to open a few weeks ago last time i checked, but it opened right before the lever was going to hit the top.
How it wont open at all.
What should i do? Get a new one? take off the fender and check if there is and loose connections of the cable?
help!
Old Mar 26, 2003 | 10:14 PM
ViperRedCRX's Avatar
Default Re: hood wont open!?? (G2-Rex)
big hammer..
nah, just try to reach under the car. between the radiator and the bumper, and get a hold of the cable, and pull
Old Mar 26, 2003 | 10:36 PM
mitsuman's Avatar
Default Re: hood wont open!?? (ViperRedCRX)
try having somebody put pressure on the front of your hood while you try to pop it
Old Mar 27, 2003 | 09:46 AM
New User
Default Re: hood wont open!?? (mitsuman)
ill give it a shot.
how do i fix it after i get it open?
Old Mar 27, 2003 | 09:48 AM
mitsuman's Avatar
take a look at it. im sure you can figure it out. i cant see it so i cant tell ya whats wrong. good luck
Old Mar 27, 2003 | 10:02 AM
New User
big hammer..
isnt the cable in the black rubber housing?
Old Mar 27, 2003 | 11:09 AM
LD_EGSICK's Avatar
take off your front bumper, then look underneathe the hood n you see where the cable is connected to then just either push or pull it.
Old Mar 27, 2003 | 11:16 AM
New User
Default Re: hood wont open!?? (mysiqu)
damn.. taking off the bumper is going to be a PITA
Old Mar 27, 2003 | 11:44 AM
Vinceg99's Avatar
Well as long as the cable didnt snap it may have just streched out so another thing you could try is to unbolt the hood release assembly (inside the car) pull it straight out (to take up some slack) and then try to open it. By you pulling it straight out you might be taking up some of the slack and then just pull on the hood release lever like its still mounted and see if that works that worked for me one time when my cable got reaqlly streched out but it also wasnt on a Honda it was on a Jeep Cherokee. Otherwise just try and pull the cable out of the hood release grab onto it with a pliers and pull. It might be that the handle inside the car isnt pulling the cable far enough. But I would try the first idea first then its just 2 bolts pull it outward then pull the handle
Old Mar 27, 2003 | 05:57 PM
New User
Default Re: hood wont open!?? (Vinceg99)
thanks but i figured out the problem. MY dad pushed down on the hood and it opened.. i cleaned up up, and now it works fine...
Old Mar 27, 2003 | 06:03 PM
FourthGenHatch's Avatar
Mine does that some times and pushing on the hood fixes it.
One time it wouldn't open at all. So I took off the bumper and then manual released the latch from under. Found out the wire had come out of it's bracket thing.
Old Mar 27, 2003 | 06:06 PM
91_hatch_si's Avatar
Default Re: hood wont open!?? (FourthGenHatch)
how do u take off the bumper with the hood still on?
Old Mar 27, 2003 | 06:11 PM
New User
Default Re: hood wont open!?? (91_hatch_si)
yup pushed down the hood and it worked! thanks! found out that it was dirty so i cleaned out the gunk and it works fine............... for now
Old Mar 27, 2003 | 06:14 PM
Same way you take it off with the hood off, hood has no effect on the bumper at all. 2 bolts behind each bumper light, 2 screws in each fender well, 2 bolts on the bottom (not one mine I never put them back) and the yank it and it will come right off.
Old May 11, 2007 | 05:35 PM
W O T's Avatar
My hood wont open tonight either
I guess I need to get a second person in the morning, but when I get it open, what are common fixes to make sure it keeps openning? Im constantly under my hood
Greg Shipley
Dec 8, 2014 03:33 AM
trustnoone5656
Feb 21, 2008 06:34 PM
Cheefed
Dec 29, 2006 09:37 PM
Smonkey
Feb 16, 2006 08:56 PM
LoudLude
Feb 13, 2003 05:44 AM
