QUICK>>Diagnose my timing belt problem--sways side to side and....
Old Mar 26, 2003 | 07:42 PM
IdahoHybridAccord's Avatar
Default QUICK>>Diagnose my timing belt problem--sways side to side and....
ok heres the problem on my 95 jdm h22a:
Part 1--
belt moves side to side on the cam gears, maybe 1/8" each way, it just kinda sways and is getting tiny chips taken out of the side of it in the same place in 2 places on the belt. damage so far is minimal. im not worried it will break because of the tiny chips, but just noticing that is is worn down a bit.
Part 2--
the belt also seems looser on the exhaust cam side. when i hold the rpms at 3k then the belt shakes badly from the front to back. when i get above that then it is steady and doesn't shake at all. the car idles smoothly also. i am changing the belt tomorrow in hopes that it will fix the problem.
could this be a bad auto tensioner?, stretched belt?, could the belt be off one tooth?
ANY ideas or comments would be helpful on this..i need answers asap if possible, thanks in advance
*note* i will post this in the tech forum but i just thought someone here could help me out also.
[Modified by IdahoHybridAccord, 9:49 PM 3/26/2003]
Old Mar 27, 2003 | 01:37 PM
Default Re: QUICK>>Diagnose my timing belt problem--sways side to side and.... (IdahoHybridAccord)
ttt, i really need some info on this.....anybody?
Kev95lx
Oct 27, 2008 04:22 AM
djviet2000
Apr 6, 2008 10:55 PM
Benhawk
Jan 29, 2007 11:49 AM
d16dcoe45
12
Nov 6, 2006 10:26 AM
IdahoHybridAccord
Mar 27, 2003 05:15 PM
