st rear crossmember??
Old Mar 26, 2003 | 04:17 PM
91hondacrx's Avatar
Default st rear crossmember??
Alright i screwed up my rear crossmember on my crx(rear half of car that the lower control arms bolt to). I know that suspension techniques makes a the rear crossmember for a 92-95 civic. Do you think or know if that crossmember could work. I understand i would have to get mine off somehow, and then figure out a way to bolt that crossmember to it but it would be worth that instead of having to buy another car. IF this works cool if not, goin to have to say good bye to the ole rex.
Thanks,
Matt
Old Mar 26, 2003 | 07:14 PM
eraser's Avatar
Default Re: st rear crossmember?? (91hondacrx)
ummm finding a replacement crossmember isnt that hard........it comes off really easy with the engine outta the car........dont sell your rex just cause things have gotten hard........the crossmember comes out with just some nuts and bolts
Old Mar 27, 2003 | 05:57 AM
91hondacrx's Avatar
Default Re: st rear crossmember?? (eraser)
I guess i did not explain it very well. But it is in the rear of the car. Where the rear suspension is, like rear sway bar, rear strut bar, underneath hatch. not bein a smart ***. Anyways, i know that it is welded on the car. So Anybody know what to do about this? I smashed it in like an inch or 2. Need to get it fixed somehow. I have positive camber on the drivers side rear, is not to bad but can deal with. Any help would be great.
Thanks,
Matt
Old Mar 27, 2003 | 06:33 AM
Geezer's Avatar
Find a body shop that does unibody frame straightening. They should be able to help you.
chriskory
10
Apr 26, 2014 05:13 PM
integ3
Suspension & Brakes
32
Dec 26, 2006 09:44 PM
cu_jarrett
May 6, 2004 08:25 PM
Civic44
Jul 8, 2002 06:15 AM
keithv
Aug 8, 2001 09:30 PM
